clutch pedal adjustment?
Discussion in 'Care & Maintenance' started by MovieSTAR, Aug 2, 2008.
    is there a way i can adjust the clutch pedal so that it releases in a smaller area. like say for example...when you clutch out you can feel the clutch engaging, but like on my Jetta, that area is alot less and closer to the top.
    if that makes any sense.
    Denver Rolla 98 impreza
    you can put in a new clutch... :)
    it is a new clutch =]
    i know.. but a stiffer clutch...
    but can i adjust the pedal =]
    There's a adjustment built into the master cylinder to clutch pedal rod. Just look under the dash.
    plu Well-Known Member
    SC
    Play with the nut behind that rod on the green box. Turning the nut in one direction raises the pedal higher therefore engages lower and vise versa.
    i was just about to say that^..
    jdm yo
    Ares Active Member
    Houston TX
    epic...
