chaqnging front wheel bearing 7th gen
Discussion in 'Stop, Drop & Roll' started by Grinder, May 23, 2010.
    Grinder Well-Known Member
    hi guys i need to chaged my front wheel bearing o9n the left side, has anyone done this before and is it easy to just remove the hub and replace it with a new one
    ya dude you need to take the hub and shit off and take it to place that will install the new one.. chances are you messed up the hub as well as the bearing. go to a shop and find out if you messed up the hub too.. if so, buy the hub assebly with the wheel and take it to a shop that will press it in for you. dont have a shop do all the work cuz it will cost you an eye. just take the hub and shit off and take it to a shop.. totall price should be about 100 bucks compared to les shwab which would be aroud 400
    ok cool thanks mate
    Rincon , Puerto Rico
    Check out my DIY page , there pressed on real easy to change all you have to do is purchase the bearing and re-use the stud . Take to a shop h ave them press it on and off then you can put it back ,
    http://rinconrolla98.blogspot.com/ :)
    cool thats what im looking for
    that what i did.. save millions.
