Changing your AC console lights DIY inside! finally here!!
Discussion in 'Interior' started by ArdotheWan, Jan 5, 2005.
    Miguel Guest
    YEp, get some red stain glass spray paint an paint the glass of the clock.
    Cape Coral, FLorida
    will candy apple red spraypaint work?
    ArdotheWan New Member
    Torrance, cA
    Ya i never got around to getting paint for it. I will update the DIY with the info I told you about just pullnig the bulbs out and more pics this weekend hopefully
    Cape Coral, FLorida
    how do you pull the clock out of the housing?
    Barnacules 100101101011011
    Duvall, WA
    I'm going to replace my clock with a www.matrixorbital.com RED LCD screen that I can hook to my CarPC to display realtime OBD2 data. I think that it will rock.
    Cape Coral, FLorida
    if u replace it can u use the harness that the clock's using and how the hell do you take the clock out in order to paint it?
    Miguel Guest
    I used a small flat head screw driver. Be carefuk though b.c they can easily snap. I takes some doing but "you can dooo it"
    Cape Coral, FLorida
    can it b done carefully with a brush?
    Miguel Guest
    Cape Coral, FLorida
    how'd u take out the 4 clips i cant get em off
    Cape Coral, FLorida
    hey is the light thats connected to the coiin holder the light for the cig lighter cuz my cig lighter has no light
    Miguel Guest
    Dunno, the method i gave worked fine for me. Give it a shot.
    Torrance, cA
    where can we get this rubylith stuff or can i buy some off you?
    Duvall, WA
    I like your switch idea but the Rainbow color scheme on the buttons has to go :) That is unless you swing that way ofcourse. Also if I was going to do that mod I would take out the ash tray and add the switches to the front of it so you could still pull it out like a drawer to get at all the wires. Anyways its a cool mod I have not seen before so mad props to ya.
    statik New Member
    I've been wanting to change my clock to red also... I have this stuff at work called rubylith, it's a red plastic film used for making positives for screen printing. I am going to see if I can put that over the clock display. Craft stores have colored film also... If someone wanted to do a different color. I'll try it out today and post results. Painting sounds good too, but that would be my second choice.
    Torrance, cA
    new mod:
    I'll update the DIY today... PROBABLY
    Only the blue switch does anything at the moment
    Torrance, cA
    Torrance, cA
    Torrance, cA
    updated the DIY with a cpl more pics.
    statik New Member
    Made the clock red...
    I tried that rubylith stuff... It worked perfectly! It's like static cling so it sticks to the plastic. I pulled the clock module out of the trim piece. Then unscrewed the 2 screws in the back, uncliped the 4 clips, and opened the module up. Be carefull not to lose the buttons, they are loose once you take the lens off the module.
    Then I just put the rubylith on the inside of the smoked lens, it stuck right to it. Assembled, and it matches the instrument cluster perfectly! Here's a picture...
    Cape Coral, FLorida
    ok hpw about a DETAILED diy on the shifter lights
    statik New Member
    If you want some, just PM me with your mailing address and I'll send it to you for free! It's cheap stuff, we hardly use it anymore, and what's 37 cents? Anyone else who wants it PM me... I'd say it's the perfect stuff for the job if you want it to be red. Matches the 01-02 S instrument lights perfectly.
    Torrance, cA
    you'll need to use LEDs for all of these namely 3mm LED's. you just need to open them up. the defroster is easy to open just unscrew it from the rest of it and open it up. you'll end up with the circuit board on my pic. then follow my directions to replace them. The AC is much harder but look at what i wrote
    CraigW New Member
    ^^ if you are talking about the single bulb in the console shifter, the easiest access (which is not all that easy) is to remove the center console and then the bulb is closer the the opening where the console was. Twist the socket to the left to remove. Bulb is a wedge type that pushes in. Console removal is 2 bolts in storage are under cloth cover and 2 screws near front on sides.
    Cape Coral, FLorida
    allright tha deforster button and a/c button? are they regular bulbs like the other ones, if so how can i acces them
    vangg Guest
    hey do you still have some of that stuff left statik?
