Can you get out?
Discussion in 'General Discussion' started by TRD-MX83, 2004年04月12日.
    CorollaAltis New Member
    waht do i do in the room with the grating, motorcycle, and firhose? i opened the curtain, got batteries, got light bulb, slide off the "welcome" carpet and keys fall off. then on the other room, a carpet with some moveable tiles. what do i do there?
    assemble flash light. Press the stones until they fall. Might be bottom left, top left, then bottom right. Throw fire hose down hole. Use the flashlight to find the key near the locker, and take that key back to the starting room and open the door.
    MikeyRolla Guest
    I cant figure out the lines with the rat head. I will try it again later. Im tired right now! :)
    put the three tablets in the slides areas. Pull the left one twice, center once, right twice. Place head in box on maze. Tada.
    vancitylover Guest
    how do i get past the room with the laser bars? i opened the panel. do i cut the wires some how?
    nomes Guest
    i could sure use a hint here...i am stuck there as well.
    SERG4U Guest
    yes............cut the wire and notice the window in one of the 3 rooms I belive that are down @ the bottem....... :wink:
    nomes Guest
    how do i cut the wire...??? i only have a stupid card!
    SERG4U Guest
    look for wire cutters....lol
    nomes Guest
    *sigh*
    thats what i've been doing.. i can't find em.
    SERG4U Guest
    hmm...check the other computers that controle the laser. It might on in there, but I don't remember how I found them.
    TRD-MX83 Guest
    did u already unlock the Big wall of green buttons? You have to unlock that one first... it will give u 2 more rooms in which you will find the wire cutter...
    vancitylover Guest
    how do i unlock the wall? i can never get them all green
    nomes Guest
    you dont have to make it all green...if you have only 4 black bricks...it will open up automatically.
    Corolla_Racer956 Guest
    help
    can some let me know how to get out of the romm with the head in the diskette box????>
    nomes Guest
    you need to take three pieces of tiles off the wall...turn off the lights and u'll see what i mean.
    in the other room... lift up the stairs, place those tiles in the three slots. Arrange the tiles so there is one continuous path and then release the head on this track. That will unlock the door for you.
    i cant get the pattern to release the damn mouse or head can some one gimme a hint or sumptin
    nomes Guest
    there are small cuts/lines on the edges of the tray...make sure to align the lines on the tiles with these cuts. u have to pull out the tiles a little bit so you can have one continous path. once that is done..releasing the head will be simple as cliking the mouse.
    aaaaaaaahhhhhhhhhhhh
    i released the mouse in the hole now wut its just cruising around, damn mouse
    SERG4U Guest
    lol.......I made them all green.......yes it took a long time, but it was fun!
    vancitylover Guest
    what's the strategy to make the wall green? where do i start?
    SERG4U Guest
    just start @ the top then work down......now if you click a spot where it is green already the spots turn black.....just work the black ones down and to the right and then all the black spots will be in one cornor......get it?
    imported_rolla Guest
    hey how do u get past the keypad w/ the smile faces buttons that keep on changing when u push the correct one?
    nm, I finally got it. damn that was long
