can someone photoshop me some rims on my car?!
Discussion in 'Photoshop' started by Junnelle Andal, Jul 17, 2012.
    I must respectfully disagree. 215 tire on an 8 inch rim with a +25 offset would not only rub, that would Mexi-poke. I have a 205 tire on a 7 inch rim with a much-closer-to-stock offset and fatties make it rub
    Milky Enlarged Member
    thats what im afraid of. i want flush. not hellaflush.
    I'd stick to a 7 inch rim if you want offset in the 20s... If you want an 8 inch rim, offset in the 30-40 range. I think.
    what size and offset are yours? i really like the varrstoens, but just dont want to rub all the time. now, im also not as low as most others, i have about 1 finger gap both front and rear. i am planning on rolling the fender lips flat as well. im not opposed to running a lower profile tire, i just dont want to go to small for when i drop the 2zz in there and have no traction till 4th.
    I rolled my fender lips in, and I have 205/40 tires on 16x7 +45 rims. Only rubs on major dips that bottom out the car, or with all the seats taken. And I'm fairly low.
    what are your spring rates?
    Added: Apr 5, 2013 at 4:38 AM
    im currently on 15x6.5's +45 with a 205/50 and i rub only on really hard cornering. i also have a couple hundred pounds in my car before and havent had a problem. tool + a few friends
    I don't know the spring rates. :deskflip:
    If you can find out the spring rates for front Neuspeed springs and rear Tein S techs you'll have your answer. :troll:
    LOL, much softer than my springs.
    Tein S-Tech
    Part Numbers: SKL02-AUB00
    Features: Linear spring rates: F 3.2kg/mm R 2.5kg/mm, Lowers F -1.9" R -1.4"
    3.0 = 168
    2.0 = 112
    so right about 180 front and 140ish rear
    cant find the neuspeed rates, but they cant be to different.
    mine on the ground controls are 300f/250r but i plan on going up to 400f/350r
    Yeah it's not very stiff at all lol. The tires make a bigger difference it seems. Since I have my steelies on right now, the tall 65 series tire makes the ride all jiggly. The car wobbles a bit just closing the door. It's a bit more solid when I have the Enkeis with the 40 sidewall.
    I roll 205 on a 7 @ +35 no rub with a mild rear roll lip is bent maybe 45-60 degrees :noidea:. Tire brand/model is a pretty big deal. My Yoko Parada Spec 2 @ 205/45/16 is almost 20mm wider than my Riken Raptor street tires @ 205/45/16.
    Didn't take into consideration the model differences. Thanks!
    With discussion, we become great.
    ^^^^ 42
    Like a sir.
    Do i know that feel?
    Nice red x
    Pictures just aren't working for you today, are they.
    Not yet.
