Engine Can someone Help Me.
Discussion in 'Powertrain' started by Drakon, Jan 16, 2004.
    Drakon Guest
    Ok, can anyone tell me if you can actually put a cold air intake with the S/C. I've read that people here have put the S/C with the intake and I would really want to know if they can be put together. The reason is I am asking is i found this site.
    http://www.toysport.com/webpages/WebUpdates/Catalog/Sportsparts/1zzfeSC.htm
    Read the *Please note...
    Can anyone give me the correct information.
    oddfish Guest
    It can, and has been done by both AESC and blk03corolla. It seems that only the trd intake will fit however. They tried the aem and it wouldn't fit
    They don't want you to install the CAI on the supercharger because it burns out the catalytic converter faster. It still works just fine though. On the S model it is difficult to fit the CAI because the filter is so large. Most people end up denting one side of the filter to make it fit correctly.
    oddfish Guest
    Its funny, the front page of the trd instructions say it won't fit a corolla s or matrix xrs and then in the instructions they have specific steps for the xrs. Go figure :roll:
    variant2 Guest
    When you have a SC installed, you're going to want the coldest possible air induced into the engine to help decrease KR. There is no negative effect on the catalytic unless you're running a very rich mixture.
    V2
    kleptohomicidal Guest
    how about just cutting a piece of the AEM CAi towards the filter, like remove the filter cut the pipe a bit and reinstall the pipe, would that work?
    holla
    j :twisted:
    Blk03Corolla Guest
    If I think im understanding you right no that wont work the bent is completely wrong and that wouldnt solve the problem
    Drakon Guest
    thx guys i finally have an answer...!!!
    now the question is should i get a S/C or wait for the warranty to finish and put turbo.
    Blk03Corolla Guest
    I will tell you what I debated for a long time which to go with and im very happy with my car. I like the supercharger a lot!!!!!
    CorollaS916 Guest
    It just really depends on how you want to go...
    Supercharger:
    Good HP, Great TQ
    Warranty (1yr unlimited miles)
    Turbo
    Great HP, Great TQ
    No Warranty
    Bottom line is, turbo is for serious quickness, speed....Supercharger is for nice add on, still fast, but not as fast as a turbo.
    Drakon Guest
    True, waranty is important, but does the S/C give more power than turbo..?? I've read that the turbo deals out more HP to the wheels than the S/C. Also how much does the S/C really give out...??
    Is it 40 HP
    Or adds 35% HP...I've also heard that it deals out 50%
    I would really like to get the facts straight before I do anything.
    Ahh yeah one more thing I read in one of the forums that the S/C has a problem with something of the fuel or something...
    How true is that...??
    variant2 Guest
    As the saying goes "turbochargers are cool but I'd rather be blown!"
    A supercharger (or blower) will give you more power and torque in the lower rpms which an engine like this could definitely use. Also, the power is almost instantaneous and requires no need for spool-up like a turbo.
    The draw back of a blower is that it is a parasitic unit. Basically, it uses some of the engines power (belt driven) to make it work.
    As to which produces more power? Well that all depends on the efficiency of the blower and your engine's ability to handle all the additional air force fed into the cylinders.
    Fuel delivery has nothing to do with whether you're using a turbo or blower. The determining factor is that your fuel system and ECU are up to par with being able to correctly deliver the right amount of fuel for your engine.
    V2
    Drakon Guest
    ok with all that stated....
    which would you recommend...??
    I really would like to sup up the car but I have to take baby steps...
    Drakon Guest
    ok question to those who have the S/C....
    The S/C peaks at 6800...does it mark that after installing the S/C or does it stop at 6500..??
    CorollaS916 Guest
    Not sure about this, but I have heard that some turbos "kick in" around 3000rpm. Yes a corolla with a supercharger will beat u until you get to 3000rpm, and then its bye bye.
    Drakon Guest
    But ain't the S/C supposed to be a constante push of massive air into the engine...???
    I kinda don't understand. I mean i know how turbo works but isn't S/C better...??
    and the question towards the rpms still stand un-answered.
    oddfish Guest
    As it stands without a new computer that moves or removes the rev limiter, the redline will stay at 6500, regardless of supercharger, turbo, or n/a. I'm a little miffed at trd for doing that :x
    variant2 Guest
    Although the supercharger's rotors constantly spin, it has a boost bypass valve that does not allow the air to enter and compress into the intake manifold under low rpm acceleration, cruising and deceleration. This increases your fuel economy dramatically.
    When you go WOT, the boost bypass valve allows all the air to enter and compress into the intake manifold and that's when you get all the power that puts a grin on your face.
    Since the boost bypass valve is vacuum controlled, it does not "turn on" at any specific rpm. Boost can be generated as quickly as you could put the pedal to the metal.
    V2
    Drakon Guest
    Ok i understand. So why does the S/C give less boost than the Turbo...???
    And how can the rpm problem be fixed, if possible...???
    Cause if it can't you won't be getting the correct dose of the S/C and for that you could accuse the trd company of false advertisement. Just because they say peak rpm at 6800 and you will never get passed 6500.
    Drakon Guest
    ok I have another question. I know that I am becoming annoying but this is the way u learn, by asking. When u put the S/C do u have to put the pistons or anything new, in other words u have to do nothing to the engine. I would like if someone is knowlgeable in this information requested.
    Good Luck and God Speed.
    oddfish Guest
    If you are getting just the trd supercharger as ordered, then no changes to anything else necessary, just bolt on the supercharger, switch to premium fuel, and you're ready to roll.
    Drakon Guest
    why do i need to change to premeum fuel and no t regular?
    whats the difference?
    the supercharger raises the compression ratio of the engine causing regular fuel to detonate.
    Drakon Guest
    and what does that mean....?? :? :?
    I'm not that good with mechanics...I'm still learning
    detonation means that the gas will explode. Normally the gas should burn, not explode. detonation causes the cylinder walls and pistons to be warn down very quickly. You can have the car detonate for a couple of seconds, but beyond that you are doing serious damage to the engine.
    oddfish Guest
    What are the octane ratings for gas in Puerto Rico?
    variant2 Guest
    I'll try to keep this as simple:
    A supercharger compresses more air into the intake. Compressed air = more heat and more heat = less than ideal performance from your engine.
    Due to the increased pressure and heat in your cylinders, a lower octane fuel will become more unstable and increase its chances of igniting before the spark plug does. This effect causes "knock" and could prematurely wear out certain engine components. If the knock persists, it could easily damage your engine.
    Thankfully, newer vehicles come equipped with a "knock sensor". This sensor (basically a microphone) listens for knock. If your engine knocks, the ecu then retards the engine timing which helps eliminate the knock but it also robs your engine of power.
    A fuel with a higher octane rating is much more stable when it is compressed and pretty much helps eliminate knock. Since the combustion is controlled again, the engine's timing is advanced and the power is restored.
    V2
    Drakon Guest
    ok I think I get it. And the octane here if I'm not mistaken is 93 is that any good. And also I've seen these little containers that you put with your gasoline. I really don't remember what the are for but I think its for that better for the fuel to burn. Are they any good...??
    :D All of your guys feedback is very well apreciated and welcome. And sorry for the lack of knowledge and the continous questions but how else will I learn :D
    oddfish Guest
    93 octane will be just fine
    variant2 Guest
    As Oddfish stated, 93 octane is fine since the TRD supercharger is manufactured to work with available premium fuel. If your engine is running fine and there are no signs of knock or ping, then there's no reason to add anything to your fuel.
    If you ever feel the need to add some form of octane booster, then make sure it is race gas or a concentrate of race gas. Stay away from the fancy octane booster stuff you would find on the shelves of typical auto stores. I've heard plenty of people having problems with them.
    V2
