Best Struts for Tein H-Tech's - 01 Corolla
Discussion in 'Stop, Drop & Roll' started by redrolla, Feb 1, 2012.
    redrolla ...........................
    So Cal
    So i bought some Tein H-tech's for my car and will be getting the struts soon. What strut do you guys recommend for these springs? This is my daily driver, that isn't really driven around that much right now lol
    Well, the Tein H-techs don't lower much at all... maybe an inch, so you should be good on OEM shocks, or step up to KYB GR-2.
    kyb-gr2s better safe than sorry.
    are u sure you're gonna be happy with the drop?
    So Cal
    yea I don't want it to be really low because it's a daily driver and I have a body kit.... trying to decide between Tokico's or KYB's lol
    What does a body kit, low and daily driver have anything to do with each other? I've got a body kit, slammed, and daily driver, and there are no problems. I say more low!!!
    Added: Feb 2, 2012 11:00 PM
    OH, and either of those shocks will work fine.
    So Cal
    ha ha ha ha... most of the streets in So Cal aren't the greatest. All I know is the front wouldn't last.
    Added: Feb 2, 2012 11:10 PM
    is there any reason why I should go with Tokico's instead of KYB's?
    Tokicos are better rate and last longer. Up from that that are koni yellows
    Tokico is more performance based KYB GR2's are SLIGHTLY above OEM grade.
    I run Tokico Blues and H&R right now, and I used to run the same springs on KYB GR-2s.
    Tokicos are much more comfortable in my opinion. They are the best choice for a daily driver, IMO. Tokicos have a much better build quality than KYBs as well. I had to ditch the GR-2s because the rear swaybar endlink bracket BROKE off under some mild cornering.
    I had 5 years and 15k miles on the KYBs (fail) and 4 years and 15K on the Tokicos (still going strong). Go with the blues
    So Cal
    Thanks for the advice... guess i'll wait a bit longer and get the Tokico's.
    What size are your rims?
    16x7 +45mm on 204/45/16. I rub in the back when there are people in there. The only way to run wheels on this gen without rubbing or rolling is to get a +47mm offset for the rears.
    So Cal
    i have 15's, offset is 40. The rear tires of my car have always rubbed whenever I have someone/something over 30-40 pds in the back seat. It even rubs without people in the back though, if i'm on fwy going high speeds and there's a slight dip in road the back will rub lol
    I always thought it was something wrong with MY car since the previous owner flipped it; car did complete 360 and landed on all 4's again.
    16x7 +40 195/50/16
    Rubbed in the back, rolled and pulled fenders and now perfect.
    how you guys have so much rubbing? Mine was 17x7+40 205/40/17 lowered 2" and I never rubbed and never modified the fenders.
    7th gens had more room in the back?
    they must have, cause all the suspension is identical.
    Yep, you guys have at least 5mm (IIRC) more clearance between the wheel hub and the fender, horizontally.
    That or you must have had some crazy camber in the rear.
    Just stock plus a drop... never got it aligned.
    So Cal
    i'll look into rolling the fenders... thinking of maybe not putting the lowering springs on the back.
    You would have negative camber without an alignment, alignments fix camber silly goose.
    Yeah, negative camber is teh sex... so it stays. Just like you have negative camber. Just like everyone who's anyone has negative camber LOL
    redrolla, you need matching springs front and back so that you have compatible spring rates. There is 0 benefit to using only the front H-techs lol.
    HummerH2O likes this.
    So Cal
    well yea I would only do that if i get impatient and don't want to wait another month or so to have the front lowered lol
    No, you won't have any noticeable negative camber on a measly 0.5" H-tech drop. Sorry.
    :p
    So Cal
    lol its all good... just looking to reduce the front tire/fender gap. I don't mind the way the back looks right now. :D
    I agree, the front always looks higher than the back, to allow for the tire movement during turning.
    Need camber kits on a ZZE110
    yes you do.
    So Cal
    What about Monroe's?... Has anyone used these with Tein's?
    I replaced the rear struts on my car w/Monroe's last year.
