Forced Induction another 4agze rebuild
Discussion in 'Powertrain' started by shubert_ae102, Aug 22, 2009.
    shubert_ae102 New Member
    de mountains :D
    ok , so now its my cars turn . . .
    i scorched the rings about 1 month ago , and have been waiting to finishup the twincharged and get it back to the owner. . . .now my shops freed up.
    this time upon rebuild ive been throwing around some ideas . . . im gonna improve the flow on the gze. meaning , internally its gonna stay pretty much stock . the head is a small port model , ported . but the factory throttle > supercharger > intercooler > intake plumbing is gonna remain in that order . . .replacing the "dogleg" gze intake with a better flowing small port unit. replacing the pewney 50mm gze TB with A 7mgte 62mm unit. this will allow the s/c to breathe a bit better. replacing s/c intake pipe with 62mm piping instead of the 55mm oem . will be a remote mount throttle . slapping in some 240 (bigport) cams to hold the valves open a little farther for a little longer. eventually will be getting 264's to replace the 240's. finish it up with a blacktop header , and 2.25 exhaust. will be squeezing a few extra ponies out of it with a greddy emanage ultimate.
    parts list.
    [x] small port head
    [x] big port cams (240)
    [ ] acl rod and main bearings
    [x] small port fuel rail
    [x] 62mm 7MGTE throttle body
    [ ] perfect circle ring set
    [x] greddy e-emanage ultimate
    [ ] adjustable cam gears
    [ ] 264 cams
    [x] ported , rebuilt head
    [ ] nst pulley kit (15-16 psi)
    [ ] water to air intercooler
    [x] shimmed oil pump
    [ ] 440cc injectors
    [ ] adjustable fuel pressure regulator
    [x] greddy sandwich plate
    [ ] oil cooler
    [ ] stage 3,6 puck clutch
    [x] smalll port fuel rail
    so far thats my list , should be good for some decent whp.
    so . . . . here we go again :rofl:
    with brandons car back in his possesion , my shop is freed up , so now i can begin work on mine:)
    motor mounts , exhaust and axles , then its outta there :thumbup:
    ive already got my cams , sp intake , piping , and fuel rail.
    other misc. "beginning" pics . . . .
    oh yeah , the head before being sent to the machine shop . .
    SaberJ2X Lurk MOAR
    Mayawest, PR
    :D! will watch!
    Edwin562 SWAG MASTER
    562 SoCal
    98 180sx
    oh this is gonna be good
    I like that home made wood round table... pretty sweet
    de mountains :D
    "tool table"
