99 Corolla work in progress
Discussion in '8th Gen' started by MacktasticSlick, 2010年01月24日.
    Well that is what you said.... not sure what's so bad about a female saying that.
    Nice update!!
    And nice Vans
    Thanks! But it's not so nice an update :kidding:
    :troll: I meant Old update
    valences can be easily fixed...fogs obviously lens has to be replaced...corner light is not bad at all, unless you are neat picky....toyota logo, i have like 5 if you need one.....bumper is also cheap
    The tabs on the corner lights are gone.
    Then how are they held on?
    both my tabs were broken from the last incident, i got an old corner light and plastic welded new tabs and brackets to the damaged one...fixed
    Gold there is also a screw that holds them on. And cBass I have a plastic weld kit, but no other lights to take the tabs off lol
    SON I AM DISSAPOINT....you've been junk yard diving these last days and did not bother getting one? 98-00 should work aswell, its the same fender n top mount
    It's not that I didn't bother, lights are the first to go. I'm surprised I found the tails. I'll just look at all the cars around and see if there are tabs that are similar.
    You could probably make your own tab anyway.
    That's what I was referencing. Break a similar tab off and make my own out of it.
    Or out of metal or scrap plastic, no need to ruin another light just for the tab
    There's a million in the yard lol
    because he is going to use pop sickle sticks or the knex pieces you used for you intake to save a corner light that no one would most likely use/buy.:kidding:
    Yes.
    Time to remove that smiley
