Engine 98 corolla engine swap
Discussion in 'Powertrain' started by koolman, Mar 8, 2010.
    koolman New Member
    Bay Area
    hey so my 98 corolla engine just failed on me a few days ago, i have been knowing that this would come for a few months. long story short i have two options, one is to rebuild the engine and two is to buy a new engine. Now i was looking into putting in the 3S-GTE because it would offer alot of power gain.
    with that being said i need to know a few things about what im doing. first will this engine fit into the engine mounts like the old one?
    Has any one done this to their 98 or 99 corolla?
    what would i need to do if i werer to put a vvti engine in it.
    does any one think i should put a different kind of engine in it?
    thanks for your help and also sorry if there has already been a post similar to this.
    JDMjody VVTLi > VTEC
    RIVERSIDE, CA
    04 Celica GTS
    i've seen it done before. idk if the guy still has it. try find you a link.
    if you lived down here in socal, i just saw a used 1zz yesterday for 350.
    SK149 Well-Known Member
    Miami
    go 2az-fe
    koolman New Member
    Bay Area
    ok after doing some research i have found that putting in a 3sgte would be a little too much money for me. but i still want to get an engine that is at least a little better, what would it require for me to put in a 1zzfe w/vvti? a new ecu maybe? and would a 2azfe physically fit into my rolla?
    whydontyouchoos KFM
    Phoenix, Arizona
    you could always go with the 1ZZ from the 9th gen corolla, just make sure you get a different tach as the redline is a little higher.
    erickscorolla1999 Member
    I asked Dr. Tweak at Phoenix Tuning before about the 2az-fe he said should fit fine just motor mounts will most likely be re-located.
    Miami
    plus 3sgte swap would be expensive it would be great hp gain but if your looking for a quick fix that's not the way to go. like i said 2az-fe cheaper find and a good hp and torque gain. cheapest way same motor or vvti it!!!
    plu Well-Known Member
    SC
    It depends how you are doing it. If you are just swapping 1zzfe blocks, then you will reuse your manifolds and ECU so you will NOT get a higher redline.
    If you are going from a non vvti 1zzfe to a vvti 1zzfe aka whole engine swap, then you will need the complete 1zzfe VVTi engine with manifolds, sensors, ECU, and wire harness. Then redo the wiring on your car's engine harness to join.
    RIVERSIDE, CA
    04 Celica GTS
    im pretty sure 3sgte swap in cali is NOT legall. ask the ref dude. or have fat fine AND car impounded. just a heads up if get pulled over.
    Its that bad in cali?
    RIVERSIDE, CA
    04 Celica GTS
    according to califonia it is. lol
    unless you can find a 3sgte from 99 celica
    Miami
    dammm i would hate that another reason why i love miami, though at one hang out over here they blocked all the exits and started to pop hoods and give tickets for iilegal parts lol sucks i told them i got a trd thats a legal bolt on :)
    RIVERSIDE, CA
    04 Celica GTS
    ^ that shyt dont fly here. they still give u ticket to have it checked out. lol
    Miami
    dammmm i would hate it i see why people move on from 8th gen corollas over there now lol
    lol I'll take the tickets
    RIVERSIDE, CA
    04 Celica GTS
    +1 lol
    they dont like my black windows. why i get pulled over.
    but imma :ninjastea so i usually avoid them and get away :cool:
    koolman New Member
    Bay Area
    thanks for the help guys.
    I got about 4 pratt and whitney jt9d's for about 500,000 dollars since they scraped the 747 and replaced it with the 777. Gas mileage sucks, but this with will make .8 past light speed. (someone guess the movie you win brownie points)
