5-Lug Conversion = Done
Discussion in 'Stop, Drop & Roll' started by t0rres16, Oct 1, 2008.
    t0rres16 Member
    Yardley, PA
    So i finally did the 5 lug conversion... heres some pix with my stock 9thgen wheels on...
    DOT. Noypi ako!
    Wow... Nice!:)
    pnyk33 300whp 4afte
    orlando,fla
    what car did you get this off of.:superconf nice job
    very nice. very jdm indeed.
    phal99 New Member
    nice drop ha3 wish my drop was like that and nice 5 lug conversion
    93geoprizm Active Member
    lol but why?
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    Looks nice bro
    lol exactly....90% of the public won't even notice that.
    yasdc05 New Member
    nice... are you gonna stick with those wheels?
    wasabinuts2go BeeP BEEP!
    Norcal
    Did you cut your front springs? Tein s-techs don't drop that low...
    seriously thats the best drop ive ever seen, thats why i bought coilovers so i can get the best drop
    JordanInc ZZE110
    u gave up the 4lug TE replicas for 9th gen hub caps? ]=
    better get rims soon!! lets start w/ the TC rims lol
    Denver Rolla 98 impreza
    those aren't hub caps.. its the alloys, same rims mine has, would look sweet with TC rims tho.. :ninjastea
    99corollarolla Member
    this is a noobie question: how'd you change the 4 lug to a 5 lug?
    drilled another hole
    :p
    He changed all four 4 lug hubs to 5 lug ones. Not exactly cheap unless you have a donor car or a connection for parts.
    crb530 Member
    it doesnt cost that much does it
    JspeXAE102 Active Member
    5X100? people usually use 5X114.3 from the Camry.
    Let's just say that when I replaced my bad wheel bearing and hub(just one), it cost 200 bucks.
    I guess you can convert to whatever you can get. Isn't 5x100 used by the 00+ Celica?
    crb530 Member
    yeah my wheel bearing was 200 to but that was for labor cause the bearing is pressed in parts are cheep like 50 bucks for a hub well a 4 lug hub that is but i dont see it being much more for a 5
    Ares Active Member
    Houston TX
    But for the other 10% that knows what its worth, thats what counts IMO.
    Good Job.
    If all my hubs/bearings went bad, I would do it too. :D
    Ares Active Member
    Houston TX
    ^ that would have been a bit more reasonable :D
    rayray1 Active Member
    there's a much larger selection of wheels if only you'd gotten 5x114.3 instead
    He can always do a 5x114.3 swap and sell the 5x100's off.
    Ares Active Member
    Houston TX
    x.x More work... Are the 5 spoke celica wheels 5x100? if so they look good too.
    t0rres16 Member
    Yardley, PA
    ^^yes they are 5x100
    lol, tell me. what is it really worth?
    whydontyouchoos KFM
    Phoenix, Arizona
    more selection of rims, and if you do the swap you could put rear breaks in while you put the new hub in as long as everythings apart
    Ares Active Member
    Houston TX
    Pride and joy... And a thumbs up from those folks...
    I have that tingling feeling inside when people look at my car and see how well maintained it is and give me a thumbs up... Those few people who do notice my car are the 10%.
