4x100 (now open for trolling)
Discussion in '8th Gen' started by MattH, Mar 15, 2013.
    and that is why i hate asking questions....
    Because you'll NPF?
    Added: Mar 19, 2013 at 2:26 PM
    I do post that pic enough lol.
    ive proven my point
    I don't think you do
    :orly: I'll keep that in mind.
    When I had ground. Control coils on my other corolla , I had to trim the spring seat to clear the tire under an extreme drop , its easier to rub at the point where the door jamb bends underneath. Than on the strut I can post pics later if it helps to show how much more clearance you get with coils
    That's too much work for the donut
    Or cbass.
    What is the overlap?
    Look here for the difference in the spring seat between ksport and the stock form factor tokico:
    Compare to how much overlap there is on your car and see!
    :dafuq:
    Or what?
    nothing is too much work for me....ive done body kit butcher, s interior swap, trd reps, and more to come....
    i need to get some different springs then if i plan on using the tires i want for the tc....i need like 1 inch clearance from the bottom of the spring seat in order to fit the tc rims.
    Side to side clearance or up/down clearance?
    Added: Mar 20, 2013 at 1:00 AM
    Wait, it won't matter unless you change the shocks. springs don't change distance from spring seat to wheel.
    up down clearance....the wheel/tire wont fit because the spring seat stops it from going in the hub. its just 1 inch....if i get coil overs sleeves and cut the spring seat or something i might get that 1 inch....
    Just get the coilovers!!
    :awyeah:
    Giggity!
    :naughty:
    Buncah DABs.
    :dafuq:
    OSPF
    Courtesy of:
    --==[TEAM HIGHER STANDARD]==--
    I can think of a couple. I noticed it's pretty hard for you to put down a donut.
    ba!
    That's not a denial. cBass -34
    pretty hard? what the fuck?
    cBass: 69
    Other: Bitch
    I noticed it's pretty hard for him to ignore a post containing the word "donut".
