Engine 4age v20 in a 2000 corolla...
Discussion in 'Powertrain' started by destca, Jul 23, 2006.
    destca New Member
    is it possible and is it really worth it to swap that engine in over the 1zzfe. how much would it cost to swap it in cuz ive seen that that engine isnt that expensive but idk about the actual work and what else is need besides the engine and such would cost.
    jtweezy New Member
    Irving, TX
    if you do the swap hook me up with the custom motor mounts......the only difficult part of the swap is the custom mounts...thats all....thats if you have a complete swap...engine, tranny, ECU, ignitor, and all that...axles......
    igorien2k New Member
    it is possible. i saw one on ebay 4 sale with a 4age 20V. but it might not be road-legal in your state because its an older engine than the 1zz-fe
    sxlostv1 New Member
    Los Angeles
    mounts are different. minor alterations required for engine to fit.
    jtweezy New Member
    Irving, TX
    well our chassis is the same as the ae111 and well they come with the 4age...just get that engine from that car...well thats what fensport said to me.
    i heard the mounts are pretty much the same. someone should check. ask dr. tweak
    Corolla DX-R AE100
    Vancouver, B.C.
    well AE100 to AE111 and anything in between hav basically the same chassis... so anything fit a 93-97 rolla will also fit a 98-02 also... but some little stuff might be different but nothing big in particular....
    JDLangevin Guest
    Yeah it wouldn't be a difficult engine to fit, probably a little redriling and grinding of the mounts or brackets would take care of it. Then it's just wiring it up, and making custom a/c and p/s lines, exhaust, and so on. Definetely a worthy swap.
    -Doc
    sxlostv1 New Member
    Los Angeles
    maybe subframe too i think needs to be swapped. from AE model corollas.
    sting Guest
    IMHO, i wouldn't swap a vvti engine for a 4age unless your motor blows off...
    if you have an older rolla like an ae92 or ae101, then it could be a thought because swapping engines on an ae101 from 4afe to 4age st 20v, is a bolt on love affiar, no problemos... just have a good electrician and mechanic who are familiar with ST's... HTH...
    destca New Member
    the only reason i asked this question was because i wanted more power out of my rolla but later decided against trying to make it fast and stick to the cosmetic aspect of the car. this also will be easier on me as far as money goes as well. thanks :D
    If you want more power, stick with your 1ZZ and use the $$ to turbo it :D
    sting Guest
    maybe, if you want to do a swap, try the celica's engine... at least its a vvti...
    jtweezy, AFAIK, the 4age blacktop, coming from ae111 levins came with vvt... just like the silvertops...
    jtweezy New Member
    Irving, TX
    there's 4age blacktop with vvti
    SaberJ2X Lurk MOAR
    Mayawest, PR
    or... go big bore, use 8.5:1 pistons and turbocharge it ;)
    sting Guest
    having a 4age ST in my ride feels so different, even with its HP gain, i am impressed... and during overtakings, its very reliable... i love my NA engine... i did have curiosities about doing the swap, but i am happy with it, a few more tweaks and i'll be fine...
    its cheaper to do engine swap here in the philippines, and less restrictions compared to anywhere... here, i've seen ae101's with 4efte engines...
    4agerolla New Member
    i have a 2001 corolla with a 4age i used the two side mounts from a 97 corolla .. the front and back will work fine .. u will need a custom made harness and axles ..i invested in this swap so much money and still not running .. i just need axles and the custom made harness.. but ill sell u mines if u want am willin to take it to the ups if u want.it already have a f1 stage 2 racing clutch.trust me i can save u alot of money .. send me and email to nene-boricua@hotmail.com ill send u pictures and stuff..i spent too much for simple things that i could of used instead.
    wheres rollatuner when you need him.."holy thread revival batman"
    x2
    got told the other day that my 1zz was as fast as a my buddies 4age.. just turbo your 1zz. invest in internals
    Gerry Martinez New Member
    Hartford, Connecticut
    I SWAPED A BT INTO MY 98 ROLLA AND USED ONLY PASS. SIDE MOTOR MOUNT FROM A AE101 AND I ALSO USED THE AXELS FROM A AE101 IT WORKED FINE IM WORKING ON THE WARNESS NOW.........
    Got any pics of it?
    yea ill take some and post em up
    bxman89 Well-Known Member
    for my swap i was think a k2o??not sure if it will work
    If you're not sure, then don't even attempt it. It's not a direct fit, like most people want. The mounting locations are SIMILAR but you will still need to have custom mounts, axles, steering rack, basically everything. Then you can try and tackle the wiring harness. Granted Hondas have very simple wiring compared to a Toyota, but still.
    Just pick up an AE111 4age half cut and swap everything over. They had this motor in our chassis in Japan. This way, all of the parts you would ever need for the swap are on the half cut, just swap everything over!!! You will need to run an adapter harness in case body harness plugs/pinouts are different. The signals though, should be mostly the same since it is the same chassis. Any good Toyota aftermarket shop will have the FSMs and EWDs to do everything by the (Toyota) book.
    coro99a Member
    Did you finish your swap to the 4age.. My 1zz Burns like a qt a week and i'm thinking about swapping to a 4age black top.. And need to know about the extra stuff you need..
    Looks like he didn't.
    That guy has 20s on his corolla. Ewww
    I noticed, lol.
    Good thing he didn't stick around.
