3157 32 LED taillight fitment problems
Discussion in 'Exterior' started by JordanInc, Mar 9, 2008.
    JordanInc ZZE110
    i had similar problems, i ordered my LEDs from v-leds.com
    and...i had to force the bulb in, and it worked o_O
    but then again i recently bought a pair for my license plate bulbs and the one on the left side doesnt fit through...i think i might need to sand it as well. good idea. haha
    Well, I bought a set of 32 LED 3157 dual intensity bulbs for the taillights and they don't fit at all... I can make them fit, but it's a pain in the ass. First of all, the bulb base doesn't fit in the socket because the wedge bottom is about half a mm too thick. The bumps and ridges match up though. I'll either have to sand the bulb base down with a grinder or drill out the socket or both. Secondly, since it's a 32 LED bulb, the diameter is a little too big. It's about 1 mm too big for the taillight hole. I'll have to grind that out a bit too. What a pain. I thought they would be PnP. I even took measurements of the clearance beforehand. The bulbs really weren't what I expected. I hope the output is worth all this trouble.
    t0rres16 Member
    Yardley, PA
    Good luck. it should look sweet when ur done thou.
    JordanInc ZZE110
    you got the wrong type of LEDs. lol
    this is why i recommended v-leds, they sell HIGH POWER/FLUX SMT ones, which are brighter and lasts longer.
    btw, if u do decide to buy from them. theres a promo code to get 10% off. the code is miata
    Thanks, I'll take a look at them. Do you use their LEDs in your taillights? I'm all jaded now. I don't want to waste more money. LOL :D
    JordanInc ZZE110
    i have LEDs in my taillights as well, i bought from them.
    when you are buying for the bulbs, make sure to look for the HIGH SMT OR FLUX or w/e ones... lol
    its kinda sad, that i bought my license plate ones recently but it doesnt fit into one my sockets ]=
    Gotcha. I guess my last pair will be 17 dollar paper weights then. LOL :D
    rolla996 Guest
    i wish there was the posibility to have individual LEDs ingrained into the tail lamp. Like A g35. That would be the shit but would risk ruining something like that?
    rolla996 Guest
    i know they make one for the new 9th gen corolla.
    Rincon , Puerto Rico
    Pics please......
    JordanInc ZZE110
    the 9th gens are altis lights
    <img src="http://i9.ebayimg.com/04/i/000/d3/ab/57db_1_sbol.JPG" border="0" alt="" />
    It's going to be a bit difficult. What I need is a heavy duty die grinder. LOL :D
    I bought a set longer from Auto Zone and they fit perfect
    Length isn't the problem. It's width.
    Anyways, I bored out the taillights and socket. I popped them in only to find out that the stock halogen bulbs light up much brighter than the LED bulbs. I can barely even see the LED side lighting up during the day. The halogen bulb I can see fine. Too dangerous. FAIL... Complete garbage and wasted time and money. A superflux LED retrofit is the only way to go.
    JordanInc ZZE110
    yeah, my friend says it does the blinker flash thingy because they are LEDs and ur car thinks that its not gettin enough power through, so acts that way. but LEDs just doesnt absorb as much power...cuz they are....LEDs lol. i think theres a way to stop the blinking though, but i dont want to. i like it all fast and look like its on steroids =D
    and if u do order, dont forget this!
    Des Plaines, IL
    You already order some lumileds? I need to rummage some junk yards for some tails lol.
    JordanInc ZZE110
    Ok. I ordered a bunch of stuff from there. I spend some time reading over the descriptions, led guides, and fine print. Seems like a reputable company. I can't wait until my REAL leds get here. LOL :D
    damn. those are bright. makes me wanna get em too. did you have blinking issues? did you need to get something extra besides the led itself?
    If you have dark housings, you should get v-leds HFR 3 watt led bulbs. They're made especially for those.
    so i bought those....i really hope they are brighter.
    my tails arent that bright especially since i have altezza black tails
    The 3rd brake light is a 921 bulb. The dome light is a DE3157.
    hey were those direct plug ins? i read you had some trouble getting them in the socket. i might pick some up
    Yes, they're PnP and no modification is needed.
    I just popped them in and they are BRIGHT. I can see them really well during the day and they come on instantly. Red bulbs through a red lens makes the color a really deep true red. It looks sexy. I also ordered a dome light, but v-leds sent me a pair of red 13 led 921 bulbs instead. ??? But instead of returning them, I'm using one as my 3rd brake and the other as my trunk light. I got a deal since the dome light was only 11 bucks and the pair go for at least 14. I ended up ordering another dome light. I hope they actually send me a dome light this time. LOL :D
    the dome light is the same as the third brake light??
    rolla996 Guest
    No the dome light is the cabin light that turns on when u open a door. The third brake light is called an axillary brake light.
    JordanInc ZZE110
