2AZ-FE or 20v 4age?
Discussion in 'Powertrain' started by EliteRolla, Sep 20, 2010.
    EliteRolla Well-Known Member
    Mesa AZ
    93 Rolla, 96 4Runner
    2AZ-FE or 20v 4age?
    Thinking about doing a swap but cant decide if i want to do some custom work and have a newer engine put in 2AZFE or rebuild a 20v Blacktop... Need opinions cant decide
    SaberJ2X Lurk MOAR
    Mayawest, PR
    I suppose the newer engine would be better for the low end torque the 50% more displacement gives you...
    which means less revving up to get you up to speed
    what are you shooting for?
    high revving madness or a cruiser?
    Do the 2AZFE Camry motor.
    Mesa AZ
    well both ha ha just want it to be a sleeper thats still simple if that makes sense ... but i need to figure out what engine i want soon so i can start it my current is on 216k miles....
    SK149 Well-Known Member
    Miami
    a black top would be simpler swap for your 7th gen
    2AZ-FE would be a poor choice if you looking for an engine that makes some higher RPM power. Though their widespread availability could potentially make them more attractive in the future. From lower RPMs, that additional torque would be immediately felt, plus it has shown to have decent power potential (big pool of quickly developing aftermarket for this engine).
    The 7th gen is pretty lightweight, that Blacktop should have more than enough power to move you from lower revs and still give you some flexibility on the higher RPMs. 4AGE has a larger following and strong aftermarket support - though finding clean examples and spare parts availability would be a concern in my mind over the next several years.
    bonspeed PHDM yO!
    Winnipeg,MB
    blacktop or 3sge.. :)
    las vegas
    rebuild the blacktop but make the compression 11:5 for higher rpm
    Grinder Well-Known Member
    build the 2azfe up by putting higher compression pistons in, as the original one are abot 8:5:1 i think ok for boost but might be weak,
    SaberJ2X Lurk MOAR
    Mayawest, PR
    I'd love to swap the ecu from my 1zz-fe and calibrate to 92fuel
    Lets do it together
    That's cute
    Cuter than a 1zz
    LOL
    Said no one ever
