2001 Rear Lower Tie Bar Installed
Discussion in 'Stop, Drop & Roll' started by Barnacules, Jun 19, 2005.
    01rollas New Member
    Put one on and you will notice a slight difference in your rear tires being more stable. I don't need one because I have the rear underbody custom spoiler and it is electronically welded to the crossmember.
    asn13oy Stepping Stones
    OC, CA
    I wanna see it!! Show us a picture of your underbody.
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    Yeah, I'm curious too.
    01rollas New Member
    let me get a camera first.
    Pic please!! :p
    i have swaybars and urethane bushings.
    Corolla DX-R AE100
    Vancouver, B.C.
    i think that little tie bar won't do anything... if it does u probably wont even feel it cuz the lateral arm is mounted pretty close together on the cross member to hav big flex on it..
    01rollas New Member
    Even though the Corolla is a unibody design it still flexes even in under the most extreme flat curvy roads. so in order for you to have a real understanding or at least from my view point is to really test it out and since i do not have upgraded sway bars or urethane bushings I really don't have a use for them right now.The reason being is since my car is so low (even though it doesn't seem that low in the pic) and the rear tires sit inward quite a bit when on launch or turning the car,it just grabs the road very,very good. With no slide even if i try and force it out the car will regain control very quickly which is why it pisses me off sometimes when i try and do some screw up slalom (zigzag) testing.
    Barnacules 100101101011011
    Duvall, WA
    I'll pass :) I need to keep it all matching..
    Hahahaha, you got BANNNED! :)
