Engine 200 hp diy
Discussion in 'Powertrain' started by dragonitti, 2005年01月12日.
    RacingSolution New Member
    They've said it.. get nitrous. .. like a 65 shot... a nitrious express kit with some useful bells and whistles will probably cost you around 600-1000 .. you'll be making around 150whp when you spray
    COROLLA1ZZ New Member
    <br />
    MWR Toyota 1ZZ-FE Piston and Sleeve Kit ,,MWR Valves - Toyota 1ZZ-FE ,Crower Billet Connecting Rods ad a few more goodied but right now meds are kicking in bbl
    dragonitti Guest
    3SGTE Block/Head/Turbo 245 HP 3rd Gen
    3SGTE Block/Head/Turbo 225 HP 2nd Gen
    3SGTE Block/Head/Turbo 200 HP 1st Gen
    dragonitti Guest
    The Celica that was built by Rod Millen Group, found Here http://www.rodmillen.com/UCelica.htm
    Is powered by a 3sgte from the 1988-93 All-Trac. produces 500hp.
    here is the paragraph from that site:
    To reach the 500 horsepower goal, TRD began work on tuning a four-cylinder production powerplant previously used in the Celica All-Trac (1988-1993). It is a derivative of the power-laden engine used in Toyota’s championship-winning IMSA GTP race cars of the early ‘90s, and Rod Millen’s record-setting Pikes Peak Hill Climb runners. The bore and stroke were increased, a turbocharger installed and Rod Millen Motorsports custom-built a set of headers made out of inconel and a stainless steel exhaust. As a result, the Ultimate Celica produces 500 horsepower at 8,000 rpm and creates 340 lbs.-ft. of torque at 5,500.
    Phozenstone New Member
    wasnt there a 500hp El Prototypes Corolla at one time? i remember watching a video of it, wut did that ahve in the motor?
    NRM NRDADDY > YOU
    Dirt poor but want fast car.
    Jeez, stupid but want Ph.D.
    What has the world come to.
    dragonitti Guest
    <br />
    3SGTE, sir.
    LoSx New Member
    uhmm 3sgte swap for 9K... i dunno.... and with 9K he can have a turbo and bullet proof engine getting over 300hp
    with a 3sgte swap you have what 200 some hp and then need to do work on that engine which is more $$
    dragonitti Guest
    I wouldn't have said so, if I hadn't already looked into it. I have talked to ToySport already my man.. Umm...Not much needs to be done to put a 3sgte into the 300 range. It's already stock turbo, and can handle over 300 I think up to 500 on the stock internals. The stock turbo I believe is good up to 400. Up the boost, and call it a day. And if you do the swap yourself, even more cost cutting.
    Straight from ToySports website:
    3SGTE ST205 w/ WATER TO AIR INTERCOOLER CERAMIC TURBO $2,500.00
    3SGTE ST185 w/ AIR TO AIR INTERCOOLER CERAMIC TURBO $1,000.00
    3SGTE ST165 w/ WATER TO AIR INTERCOOLER $800.00
    These are J-spec. engines. For tranny add about $750 I think. Also the guy suggested buying new piston or piston rings, I can't recall.
    Labor if they were to do it would be around 2 or 3k. So, like I was saying 3sgte is more cost effective.
    Thanks maracingsolution and losx you 2 got it right.
    Parts
    Crower Billet Connecting Rods $748.00
    MWR Toyota 1ZZ-FE Piston and Sleeve Kit with coated skirts $829.00 + $79
    MWR ARP Stud Kit - Toyota 1ZZ/2ZZ Cylinder Head $135.00
    MWR ARP Stud Kit - Toyota 1ZZ/2ZZ Mains $105.00
    MWR ARP Stud Kit - Toyota 1ZZ Exhaust Manifold $45.00
    MWR Valve Springs - Toyota 1ZZ-FE $250.00
    Timing Gear Kit $404.71
    Water Pump $66.58
    gasket set $299
    oil pump $190
    sent block to monkey wrench $650
    crank $375
    Clevite 77 Race Rod Bearings and Main Bearings $243
    port and polish and new valves and seats $1200
    tp pull engine and tear it down and send block off and get it back , punch the block out when it came back install it back with oil and filter labor and all my shipping charges with all my other parts.
    $3000
    If I ever get my turbo from SF that would be cool $3600
    I am not sure if I want a piggy back ecu or a stand alone one. What would be the best way to go and what brand?????
    red 03 corolla s Guest
    wow why start shit with everyone out here you dont even own a corolla or an engine with vvti for that matter. in fact the car that i drive, a corolla, has greater displacement than your car does. how sad is that, a corolla with more displacement that your car
    as for the question at hand, here are some easy ways to boost your Crank hp to 200
    lightend pullies set= 300$ roughly
    full cat back exhaust= 200$ roughly
    header piece= good one with down pipe 200$
    cold air intake= 150$ roughly
    cams= N/A
    cam gears= N/A
    to be honest there really is no cheap way to get our cars up to 200, best bet would be by FI which would be around 2500, sorry bro you should probably start out with a car that is already fast if you wanna go 200hp cheap
    you knew you were going to get flamed when you said that lightend rims=hp <img src="http://vvti.net/forums/images/smilies/smile.gif" border="0" alt="" title="Smile" />
    D Rolla Guest
    you guys crack me up :D
    yo i love your hood accent how much was that?
    also what cracks you up? i like discussion....especially if it deals with slow ass scions
    kinda funny he would post in this thread, and for him to think he has ANYTHING to say. my god it would take 1000's apon 1000's of dollars to get his car anywhere near 200hp
    <br />
    it only costs about 500 to have a pro install it for you a kit that is
    yo you actually can build your own turbo fool all you need is the actual turbo spool, and have some custom fabricated piping...there is a shit load of people in this world who have custom turbo set-ups. one that i know of on this forum is (crovax) which he spent around 3g's to have someone custom build one for him. his kit (like many other people's) was not "pre-fabricated" so to answer your question you can build your own turbo kit, is it cheaper could be if you know what your doing...i will have some honda people vouch for me on this one cause i know your going to try and flame me
    91DX Guest
    ummm i'm pretty sure that DIY means you do EVERYTHING yourself. so unless you own a machine shop or have some friends who have the right equipment you cant build a turbo kit by yourself. <br />
    <br />
    and wtf is a &quot;turbo spool&quot;
    turbo4age Love to Hate me
    NV
    ..... it just keeps getting worse and worse
    its hard for me to find the energy anymore to reply to all the misinformation or idiots
    im officially in retirement
    shit i ODed
    if you have all the parts you can infact install a turbo YOURSELF, hence DIY 200hp the thread name. i was merely stating that it is cheaper to go with a custom set-up and to do it yourself rather than to buy a fabricated kit...technically speaking if he owned a machine shop he could do it himself...also a header DIY does that mean because he didnt make the header that technically it shouldnt be concidered a DIY part?
    slvr2000fdvspec Guest
    i've been, thats why i rarely participate in any posts anymore other than general and off topic
    93corolladx Guest
    I agree. I wouldn't say I have a large knowledge of cars but these &quot;how can i get a easy 200hp&quot; threads are ridiculous.
