1ZZ-FE Supercharged
Discussion in '8th Gen' started by SR71B, Aug 9, 2014.
    SR71B Member
    Oregon (nothing but trees.)
    2001 Corolla LE
    I had an idea.
    I know the TRD superchrger isn't exactly perfect for us.
    I have 1zzfe with VVT-i, so what's the issue?
    Hood clearance.
    I don't want to be all rice like and have a cowl, so wouldn't hood risers work?
    I figured a supercharger and standalone ecu w/ a manual tranny would be way more simple than a 2zz/c60 swap.
    Thoughts?
    Yinster Well-Known Member
    Hawaii
    Hood risers won't work. Either run a bulge like a M3/LFA hood style or you're shit out of luck
    MP220 Well-Known Member
    CT
    2001 Toyota Corolla CE
    Well, it wouldn't really be rice since you'd have a supercharger underneath...
    a cowl wouldn't be "rice" since its a functional cowl that you need to have clearance for a supercharger to fit...
    Irvin and Milky are the guys to talk to about supercharging an 8th gen.
    Hood risers lift the rear of the hood, the supercharger would sit up front.
    FriskyDingo Well-Known Member
    Canada
    2000 Corolla CE
    where does one come across a trd supercharger anyways i ahvent seen any
    I got mine off eBay. matrixowners, 9th gen forums, newcelica also have them occasionally.
    ccarlisleIII Toast.....mmmm toast
    Anaheim, Ca
    2002 Toyota Corolla LE
    98 Corolla
    Fucking boss dude.
    What's gonna go over the gaping hole?
    Could you kindly provide a top-down picture of your cutout, that I might be able to use as a template in the future?
    Thanks!
    Nice!!!!!
    nice
    CorollaNation New Member
    Need helpful tip on power ???? Can sumone assist me?
    What do you need to know ? and remember there is no such thing as cheap power
    overdosevtec Active Member
    NY
    1999 Chevy Prizm
    aint that the truth, just finished the turbo set up on my 06 civic. :facepalm: I dont even get to drive car like I used
    Anaheim, Ca
    You mean with measurements and stuff? The width of the hole had to be about 12" minimum but since I wanted to center it I made it about 17" and the length from front bumper to winshield was, I believe, 7". Not sure on exact measurements but with a measuring tape and the hood you want to cut installed it's not that hard. Helps to have a friend, but not 100% necessary. Ryan helped me out though
    Anaheim, Ca
    Hey thanks for the response and for the pictures that Irvin asked for last week.
