12 inch subs
Discussion in 'Interior' started by Vibe, Apr 18, 2007.
    its taking that long because of having to make holes for the tweeters and i want them to dynamat the exterior interior part of the door if you get what i mean (putting pieces of dynamat through a hole big enough to fit the hand.
    dward3 Well-Known Member
    Phoenix
    Don't forget the band-aids :D
    Ares Active Member
    Houston TX
    Oh yah... Dynamating can be troublesome. Altho vamp made it look easy on his page.
    i managed to pull the white plastic panel thing holding down the carpet and dynamatted the floor. I then went to the driver side rear door and popped off the same plastic trims but i decided not to mess with it since thats where the wires are at and they're getting in the way.
    the noise is def starting to tone down slowly :)
    alright, so far, i've installed everything.
    alpine type-r 13s front door speakers w/ tweeters and crossovers and alpine type-r 17s rear deck speakers with the tweeters etc.
    what kind of amp should i get? by the way does anyone know how much amperes our alternators dish out?
    Alpine MRP-F450
    what do you guys think of that?
    Phoenix
    How many amps are you buying?
    just 1 lol they're expensive
    Phoenix
    Thats a nice 4 channel amp. you should be able to shake your trunk lid :D
    yeah will that be sufficient to hook up all 4 speakers and a subwoofer or will i need another amp for speakers and sub?
    Phoenix
    I think you'll lose the fade.
    hey i requested to be added on your yahoo. i think it'll be easier to talk over some kind of instant messaging.
    but what do you mean the fade? how will i lose it?
    Phoenix
    Between the 4 mid-range speakers. you'll lose the fade because your fronts and backs are ran in series.
    so you're saying i should rewire it so that it's run parallel to the amp?
    can you explain fade? gradual increase/decrease inn volume?
    Tulsa, Ok
    x2
    Phoenix
    Nice amplifier. you would of been okay with 4 channels :)
    yeah but i would have to buy a seperate mono amp for the sub.. which i should have done but i already paid for the 5 channel one..
    he got his head unit today =]
    his im woke me up...ass
    LOL awesome
    too bad i cant connect it. need some wiring and might as well hook it up when i get my amp so that i can run the rca cables the same time.
