09 Corolla S Rear Disc Brake Conversion
Discussion in 'Stop, Drop & Roll' started by |-Goku-|, Apr 8, 2009.
    Would there be anyway to just take the Discs(and whatever parts are needed) from an XRS and put it on an "S"??
    I was thinking about getting the discs parts from a damaged XRS, but would like to know what I would need to do, to make everything work propery.
    Thanks for the help in advance..
    |-Goku-|
    Graphiterolla Member
    Macon/Warner Robins, GA
    it was pretty simple for mine. just take thw whole rear hub off the xrs. once you get there and see it, you will be able to tell what and how to take it off. its really only a handful of bolts. i took the brake cable from the ebrake back and the whole rear hub and then it is just take yours off and put the xrs setup on.
    whydontyouchoos KFM
    Phoenix, Arizona
    for the 8th gen corollas, there was a brake fluid resevoir that we also had to take from the donor car, but thats the only other thing i can think of
    Do you have a 10th Gen Corolla??
    7th gen but is like anything else. the basic premise is the same
    Hmm, Wonder how much it will run me, Will I need a new Brake Master Cylinder??
    I know about getting the Valve for all Disc brakes so that they get the right amount of Fluid.
    whydontyouchoos KFM
    Phoenix, Arizona
    i dont think they would change the brake master cylinder between trims, too expensive to do something like instead of just doing the valve
    Goku.....check out a local toyota dealership. tell them you need rear disc brakes for an 09 xrs...it should bolt on your setup.
    Kansas City, KS
    I work for Toyota. Besides the rear disc, hubs, ebrake cables, lines, and ABS sensors you dont necesarily need to change the master cylinder, a proportioning valve (usually mounted on the firewall) is needed to equalize pressure more evenly on all 4 corners, rather than stock one which sends less fluid pressure on you drums. The one from XRS or Matrix may fit if u give it a try.
    Cool, Thanks for the answers guys
    I will be checking into this later this year :D
    Any one know where to get a caliper upgrade for 98 - 02 corollas?
    I still have Cross Drilled Never installed rotors for sale for the 98-02 Corolla!!!!
    Thanks for the information.
    I was actually looking for just brembo calipers, not the entire kit, since i already have all the other stuff in the kit. Just need calipers.
    I searched almost everywhere, except the place that they sell them, but can't find them.
    Want brembo or nothing :-D. Love brembo, don't know why.
    Cjn2it4eva New Member
    California
    Does anyone know how involved /doable a rear rotor disc conversion would be for a 2001 corolla? I want to convert the stock drums to rotors. What is needed for that?
    Just stop by your local mechanic, they will figure things out for you. It's also posted somewhere on this forum.
    dr tweak at phoenix tuning sells a kit for 500 dollars.
    There's a DIY on Vamps website as well.
    oh and most local mechanics will laugh at your for changing out your rear drums with discs. its an asthetic mod only. your drum brakes will perform just as good as disc brakes unless you are running a circuit.
    Just do your fronts.
