Engine Yaris Engine Guide
Discussion in 'Powertrain' started by teevee247, Apr 5, 2007.
    teevee247 Well-Known Member
    Montreal, QC
    Yaris Engine Guide
    ECHO - 2000 TO 2005
    1NZFE VVT-i - 2000 TO 2005
    1.5 LITER DOHC INLINE-4
    108 HP @ 6000 RPM
    105 FT-LBS @ 4200 RPM
    YARIS - 2006 TO PRESENT
    1NZFE VVT-i - 2006 TO PRESENT
    106 HP @ 6000 RPM
    103 FT-LBS @ 4200 RPM
    Tulsa, Ok
    So, I think someone brought this up in the past....but remind me, what swaps can fit into the Yaris??
    I think the 1ZZFE and 2ZZGE can fit(1.8 liter). The 4AGE and 3ZZFE will as well(1.6 liter). These might be a tight fit. However the turbo tercel motor, 3ETE will fit no problem since its a 1.5 liter. Its just finding one that would be hard.
    3E-TE SOHC 3 86- 1456* 113@5600 127@3200 2.87 3.43 8.0:1
    The Yaris aka Vitz had a special version called the Vitz RS Turbo which uses the same 1NZFE. However the displacement for the Vitz RS is only at 1.3 or 1.4 and uses a T25 turbo. The motor is rated at 150 hp and 148 tq. There seems to be some problems utilizing the turbo system from the RS in the US Yaris. It's probably best to just do a swap.
    bump for any engine swaps?
    JDM Vitz turbo gen 1 motor. Its most likely called the 1NZFTE or 1NZGTE.
