Engine WRX stock turbo....
Discussion in 'Powertrain' started by corolla_racer, May 18, 2004.
    corolla_racer Guest
    i'm getting it this friday...so...hehehe......If the stock turbo doesn'twork wat turbo should fit the my 95 corolla then???
    dopeee Guest
    i thought the wrx had an aluminum engine...
    corollarider19 New Member
    i second that one
    polo708 New Member
    9thgencorolla.com
    $75, buy that $hit anyways... u could always sell it if it doesnt work out
    02RSX Guest
    i thought regular WRX had 2.2 or 2.0. the RS and the STi have 2.5's
    BigTymer2k3 Guest
    If it is a 2.0 or 2.2 its still enough of a difference to create a pretty noticeable lag. And boost will cut off earlier too. If you get it cheap, sure why not. But if your serious about doing a really good turbo setup, look for a K03 that come off the 1.8T VW/Audi motors. Thats the perfect size for a Corolla.
    BLADDER_MASTER Active Member
    FL
    WRX's are 2.0L. WRX STI's are 2.5L. 2.5RS are 2.5L. Get the turbo, it's cheap. If it don't work out for you then you could always sell it to someone else at a higher price.
    dude buy it anyway and sell it for more
    Paolino SolidTuned
    RAF Molesworth, UK
    Be careful with that. I remember talking with two of my friends who are WRX owners, and they mentioned that the Corolla's engine is all-alluminum, and the internals of the engine may not be suitable for forced induction like a turbo, especially stock. But heck if it works, let me know. lol My friend is selling his too.
    FL
    It's possible. There's a couple of guys with Corollas on this board with turbos.
    corolla_racer Guest
    WRX stock turbo....
    Hey wat do yalls think about a stock WRX turbo..In a corolla???????...Because mny friend is selling his stock turbo for 75.00 only......I'm going to go get it so wat yalls think????....He needs the money so that he can get a bigger turbo for his WRX......
    BigTymer2k3 Guest
    I'm pretty sure IHI makes the Subaru turbocharger. Isnt a WRX 2.5L though??? With the Corolla 1.8 or 1.6, that turbo will be 'just a little' :rolleyes: big.
    u can turbo a corolla you just have to change some of the internals
    ahem.. compressor maps
    Prodigy3006 Rubber Man
    Alabama
    turbo is more and more likely becoming an upcoming mod :evil:
    Mike4831 C-Town Pimp
    Statesboro, GA
    A WRX is a 2.0L. It should fit. I mean the thing isn't huge.
    prophesized Guest
    just install the turbo in a powerwheels jeep
    Paolino SolidTuned
    RAF Molesworth, UK
    I'm not sure. It might, but I bet the internals are better equipped to handle it... I dunno too much bout it. just some insight.
    Bladder Master,
    Really? Cool, I need to find some of those posts then. I want to turbo the XRS as soon as I get it.
    Concordmk1 Guest
    Why not a TD05 Mitsu turbo? :D
    LowRolla Will work for turbo
    Oviedo, FL (orlando)
    it has nothing to do with what substance the internal parts are made from - hell Ferraris are 100% aluminum :rolleyes: - it's all about what kind of abuse they're designed to withstand. the aluminum internals of a WRX are designed specifically to withstand boost. The internals of the corolla engine are not.
    TurboRolla21 Guest
    Is that turbo bigger than a T3/T4??? I have had my turbo kit since 1/7/04 and haven't had any problems with boost as of yet. It will hold up as long as you dont push the boost too high. I am on 5lbs to be safe for now. I wouldn't go over 7lbs though.
    Deathsight Guest
    You can turbo a rolla. Dont have to change any of the internals. The engine alone can hold up to 300 hp. Now the tranny I think it can hold around 200. Talk to the guys here that have turbo rollas. Its been done already.
    02RSX Guest
    ge head swap on those is a bitch, and kinda pointless from what i've read. and btw, i've seen turbo kits for the 7afe on ebay all the time. I remember one old member (rg94yota or something like that) was selling his, not sure if he ever sold it.
    Fox New Member
    Under your sink.
    Has anyone here used a K03 Turbo for their rolla?
    matadorCE Guest
    for a 1ZZ?? how do you know this???
    CadetLee Guest
    IIRC, Toyota has stated that the 1ZZ block can handle 300hp.
    matadorCE Guest
    hmm...I"ll file this one under the "I'll believe it when I see it" folder.
    HighRollN95 Guest
    what about the 7afe with stock internals what can that engine output? because I've been interested in doing the turbo kit that includes a T3/T04 Garrett turbine (ball bearing is what I want)....but I want know some more about the K03 turbine...if VW/Audi 1.8L's come with that then do they come with front mount stock intercooled systems or what car would it possible to get on from...since I have an engine close to 100,000 miles on it I would like to build a custom turbo kit and probably do a 4age internal head swap unless i wouldnt have to do that...
    TurboRolla21 Guest
    The engine can handle the power gain...It IS the tranny though that is a little suspect. With only 5lbs of boost, its still too much torque for the tranny. For those of you that are going to do a tranny swap, I would suggest looking into making it a little stronger first. My sycnchro's are going out in 2nd b/c second pulls so hard!!!
    You have to be carefull with 2nd gear, b/c it hits hard!
    superpilun Guest
    turbo 1zz's are a dime a dozen. there are a lot of turbo corollas and celicas out there especially under stafford's kit. they can run totally stock safely up to about 9psi.
