Wood screw direction
Discussion in 'General Discussion' started by CraigW, Sep 30, 2004.
    CraigW New Member
    You may need an EZ-Out to remove it. Crasftsman makes a set for stripped heads, this is more of a broken bolt situation. CW
    CraigW New Member
    Craftsman !!!!
    midniterains Guest
    you can always drill it out and retap it if you have the tools for it too
    System Error Guest
    I have a question. I need small a screw....one with a point on the end like a wood screw. BUT...I need it to go the opposite way of our standard screws.......(i need "lefty tighty right loosey") I need counter clockwise to go in to the object...and CW to pull out. ANyone know where I can get a hold of one????
    I need to pull get a tiny stripped screw out of a tiny little hole........my boostcontroller...one of the screws you use to adjust the boost is stripped so I can't get it out.
    corolla_man_j Guest
    go to lowes and they have a screw-stripper-getter-outer. It isn't that fast
    ChristianVA New Member
    System Error Guest
    you can't rethread it, because only 1 screw fits in it....... so you can't make the hole any bigger......I was thinking about putting some JB weld on the end of the alan key..then putting that inside the screw and let it bond together
    midniterains Guest
    you dont make it bigger, you drill it out.
    e_andree E
    MD
    Ya drill a small hole in whatever is stuck....then you back it out.......
