Witch amplifier for the subs ?
Discussion in 'Interior' started by Left-Track, 2004年02月14日.
    Left-Track Guest
    Hi, I just order 2 Rockford Fosgate RFD2212 12" sub
    Here's the spec of each :
    Impedance 4 ohms
    RMS Power Range 150-500 watts
    Peak Power Handling 1000 watts
    I already got an Alpine 9807 unit with 2 Boston FX6 at the front and 2 Boston FX9 at the back.
    Witch amplifiers should I buy for my sub ??
    Do you think I need an amplifier for my 4 speaker two ?
    tx for your help !!!
    darrenwang Guest
    You definately need amplifer.
    What's your budget?
    dragonfiyah513 Guest
    i'd get a rockford amp
    i have two 12" rockford he2's wit a 1800watt rockford amp
    shits mad nice
    Left-Track Guest
    I'm ready to put enough money to get something good !
    CorollaX Guest
    use rockford fosgate amps, alpine amps, or the JL audio 1000 amps
    Left-Track Guest
    I don't know much about the OHM.
    I want to get the 2 rockford 501bd but it's says only 250w at 4 ohm and 500w at 2 ohm.
    So my sub will receive only 250w ?
    subwoofy Guest
    its a Dual voice coil subwoofer right? Two Dual 4 ohm woofer means you can either run them at 1 ohm or 4 ohms or 16 ohms depending on parellel/series combination you choose... If i were you i'd find a different amp that will run at 1 ohm because that way you'll get way more power for your money.. you'll probably be dimming your lights a lot more though..
    Blue_Diamond Guest
    you spelled which wrong.
    zhentipede Guest
    lol spell checker man chill hehehe :wink:
