wiring diagram 2003+?
Discussion in 'Interior' started by Magister, May 23, 2003.
    Magister Guest
    Does someone has the wiring diagram of the 2003 or 2004 ? I plan to install an alarm with door lock/unlock and remote starter, and would need the full diagram, PDF someone? thanks :)
    ConwayJim Guest
    Yeah...i'm also curious of the wiring diagram for the stock HU. Can somebody post the legend?
    Jae Guest
    They are selling it for 40-50$ US on ebay last time I checked.
    Go buy it :)
    darrenwang Guest
    What do you need to know? Maybe I can help.
    ConwayJim Guest
    Just curious what each colour is, i'm pretty sure i know which each wire is cause i just matched it with my old 99 wiring harness, i just want to make certain.
    The reason for this is because, i'm going to be using the stock hu as my perminent source for my stereo and i wanna cross my amps to the front speakers and add in a line driver and equalizer...etc...
    thanx in advance
    oxymoron Guest
    Here's a photo of the harness wiring spec. I know it says '89 '90 and '91 models, but they've been using the same spec since 1987.
    Note that the Corolla doesn't have a wire in the harness for pin 9 on the 10 pin connector. That's the one you want to use to turn on your remote amp and the head unit does output it.
    ConwayJim Guest
    Ok thanx man...
    just to clarify, pin 9 is the remote wire right? (typically blue)
    oxymoron Guest
    statik New Member
    Here is the alarm wiring details you will need,
    Code:
    |       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
    |              12V|white & black       |+  |ignition harness            |
    |          STARTER|red                 |+  |ignition harness            |
    |         IGNITION|black/yellow        |+  |ignition harness            |
    |  SECOND IGNITION|black/white         |+  |ignition harness            |
    |        ACCESSORY|blue/red            |+  |ignition harness            |
    |       POWER LOCK|green *1            |-  |passenger kick panel        |
    |     POWER UNLOCK|blue/black *1       |-  |passenger kick panel        |
    |       LOCK MOTOR|blue                |   |driver kick, door harness   |
    |     UNLOCK MOTOR|red                 |   |driver kick, door harness   |
    |    DISARM DEFEAT|red                 |   |driver kick, harness to rear|
    | PARKING LIGHTS +|green               |   |driver kick panel           |
    | PARKING LIGHTS -|green/white         |   |headlight switch            |
    |       HEADLIGHTS|red                 |-  |headlight switch            |
    |     DOOR TRIGGER|red/yellow          |-  |driver kick panel           |
    | DOME SUPERVISION|comes on with unlock|   |                            |
    |  TRUNK/HATCH PIN|red/white           |-  |light in trunk              |
    |       TACHOMETER|*2                  |   |ignition coils              |
    |       BRAKE WIRE|green/white         |+  |brake pedal switch          |
    |     HORN TRIGGER|green/white         |-  |steering column             |
    Notes:
    *1 These are the passenger key cylinder wires. Meter the wires while turning the key in the passenger door.
    *2 Go to any one of the ignition coils under the black motor cover and use red/blue, yellow/green, gray, or white.
    .Activation In
