Winter GRIP!!!
Discussion in 'Stop, Drop & Roll' started by ChicagoCruise, Dec 13, 2009.
    Winter GRIP!!!
    hey guys,
    I did some research but i wanted to ask if anybody had anything to add.
    I have a set of stock steelies that i want to place a set of winter tires on. Now the tires I have been considering, are 185/65/14. Now I know the rims will handle 195 but would they be wide enough to handle 195/75/14? Is it even worthwhile to go to bigger? I rather have it wider, but Winter 185/75 are not to common.
    thanks for any input
    nyrican52884 Active Member
    Plymouth, MA
    After doing a quick search on Tirerack, the 195/75/14 will fit on a 5-6.5" rim. So yes they will fit the rim, but the diameter of the tires is 25.6" and the stock size is 23.4". The tires will be too tall, and you will probably rub like crazy if anybody is sitting in the back seat, even on stock suspension
    can u show me where you found the measurements. As long as 75 fits on the current rim, thats the most important thing for me.
    Unique102 Well-Known Member
    I just put Dunlop SP60s on my steelies. I read that for a winter tire it is better to run the stock width then wider becasue a skinier tire pushes through the snow better. Put another way, the wider the tire, the more mass that has to be moved through the snow. Therefore I went with the OE size.
    Plymouth, MA
    That is true. I knew some Jeep guys that would go with a thinner tire, but get it with an 85 series tire. You should probably get 175/65/14. Thats what came stock on my car. And since theyre slightly smaller, you'll get more power to get out if youre stuck
    thanks guys,
    Really appreciate all the info.
