Window visors
Discussion in 'Exterior' started by slowrolla, Apr 16, 2008.
    slowrolla New Member
    Window visors
    I was wondering for those who have it, does it quiet down the wind noise? My G/F's corolla makes tons of wind noise on the highway and hates it.
    DeebsTundra Big Tires :)
    Near VoRtEx
    It depends on the type of visor. It also depends on how far you roll the window down. I use the WeatherTech Inchannel, which I think is quieter than the double side tape version that adheres to the outside.
    But you are still going to get alot of wind noise with them. Rushing air at 70 is going to be loud no matter how you slice it.
    The reason I have them is so that I can get some fresh air in the truck while it's raining and not have my arm get soaked.
    I recommend you check the door seals. I had a split on one of mines which created a lot of wind noise, it quieted down once I replaced it.
    e_andree E
    MD
    Yeah, you shouldnt really have a lot of wind noise. What year is her corolla
    Aren't all window visor almost the same? Or are some better than others? The window is closed and still makes a lot of wind noise.
    slowrolla added 0 Minutes and 47 Seconds later...
    I will check on that, thanks.
    slowrolla added 1 Minutes and 28 Seconds later...
    93 corolla. Would it help reduce the wind noise a lot?
    e_andree E
    MD
    Check her door seals, and wheel well liners, etc etc etc.
    Near VoRtEx
    If you have alot of wind noise with all the windows up, you have a weatherstripping, and seals. You should have virtually no wind noise with all the windows up.
    JordanInc ZZE110
    window visors = +10hp yo
