Window Rattle?
Discussion in 'Truck & SUV' started by DeebsTundra, Sep 13, 2006.
    DeebsTundra Big Tires :)
    Near VoRtEx
    Window Rattle?
    I've got an irritating rattle in my driver's side window running over rough roads.
    I've heard reports that it's the window regulator.
    Anybody shed any light on this? ...and possible cost to fix? Like the squeaking in my springs, the rattle is driving me crazy.
    DaCubanSkillz Active Member
    Have you tried taking the door panel off and tightening any loose screws/bolts? I would check that cause it would be a waste of time if you took it in and that was the cause.
    Near VoRtEx
    Whoops, guess I wasn't specific enough. The driver's window only rattles when it is between 1-5 inches down. ...I can grab ahold of the window and pull it in towards the cab and it will immediately stop.
    This is what I would do. Take off the door panel and bring the window down 1-5 inches. move the window back and forth to see if it wiggles...if it does, then tighten the screws that hold it in place. if you do not see anything moving, then take it to the dealer. do a search to see if there's a TSB out for it or not. that way you know if its only your car of if its affecting others.
    My03Tundra ROLL OUT!
    Tucson, AZ
    There was a TSB for it, and it does indicate replacing the window relay motor.
    Some intrepid folks have fixed it by using some felt stuff in the window tracks. The main problem with doing that is if dirt gets in there, well, you've got a nice scratch.
    If there's a TSB out, then take the truck in. Let them fix it. No point in trying to fix it then.
    ya know now that i think about that andy... i had a similar problem with my other rolla... turned out to be part of the rubber gasket was all messed up... apprarently the gasket goes all the way down into the door to help out with keeping the window stable.
    Denver Rolla 98 impreza
    happens with my rolla now... Imma gunna take her in some time... :)
    YamahaTundraV8 New Member
    Atlanta (burbs)
    the window regulator need's to be replaced
    It's a Tsb i got fixed and mentioned to you and pull out your panel and stick foam spray on the track that seems to also work...
