Engine Will this Dual Muffler fit on 03 Corolla S?
Discussion in 'Powertrain' started by djkl407, Jul 2, 2004.
    djkl407 Guest
    n0b0dy Guest
    looks like you already bought it... so you have your answer :)
    but in any case where you're buying from ebay, have your answer from the seller IN WRITING so you can't go wrong :) cheers
    djkl407 Guest
    well would it fit tho?
    APC_MATRIX_ Guest
    Yes, but why have the dual thing? All that does is make more back pressure cause of the stupid split thing in the front where it directs gasses into each can. Why not just go with one and be cleaner looking and a better gain?
    CowboyBebop Guest
    do you want it to be below the back lip? Or do you want to cut a hole in the lip for a closer fit?
    RexPelagi VDub
    Canton, Ohio.
    I would think it would fit, pretty sure its universa, but ya you may need to cut the lip.
