Which light?
Discussion in 'Interior' started by Vibe, Sep 21, 2007.
    Which light?
    I'm torn.. this is for my front turn signals.
    11 Super-Power Wide Angle High Flux LEDS
    These Bulbs have Advanced Patent Pending Control Circuitry Found in no Other LED Bulbs
    These are the most advanced and brightest led automotive bulb assemblies ever produced.
    More powerful, consistent color and more stable than any other automotive leds made.
    1 Super High Powered 3 Watt Wide Angle Flux Forward Facing Led
    10 Side Facing Wide Angle High Powered LEDS
    Fits thru the standard 1" diameter hole.
    or
    These bulbs are spring loaded so they can fit thru the tiny hole in the bulb housing, and then toggle open for a super wide field of light.
    These are perfect for round shaped bulb housings and lenses.
    Super High Powered SMT Leds
    The spider lights won't fit. I wouldn't get either. You want as many high powered LEDs on the terminal end of the bulb tower. LEDs are bright, but it's hard for them to match the output of a halogen.
    the first one!
    on the website, it claims it can fit in the 1" standard hole. if it doesnt i can just return 'em. though I dont think i'd get spider lights for front turn signals..maybe for brake lights it would look better.
