Engine where to get 5 speed trans for my car
Discussion in 'Powertrain' started by mikefik, Jul 31, 2004.
    mikefik Guest
    im buying my sisters corolla because she cant afford it... it has stock 4 speed auto, anyone know where i can get a 5 manual for it?
    hooolala Guest
    Re: where to get 5 speed trans for my car
    www.car-parts.com
    rolla_dink Guest
    you probably need the ECU for the 5 speed too.
    mikefik Guest
    hey sorry for being such a noob but whats ECU.... you see i was supposed to get a 2002 Lexus IS300, but then my sister screwed us all over and put herself into debt... so now i am being forced to buy her car from her because im 16, and a car is a car they tell me... so since i had my hopes set for a quick car... and now im stuck with a corolla i gotta find ways to make it quick.... thanks. any suggestions are accepted PLEASE and THANKYOU
    rolla_dink Guest
    it's the computer for the car, the engine control unit.
    APC_MATRIX_ Guest
    There are a ton of parts to swap out for the conversion. It's not worth it unless you know what you are doing and have done swaps before (lots of them).
    I swapped my tranny out for another manual one (with an LSD in it) and it was the biggest pain ever. You basically have to take the whole front end out from the bottom (excluding the engine and front fenders). It's more work then I thought it would be and that wasn't even converting it, that was just replacing it :?
    You'll need the ECU, all the clutch lines, all of the senders and wiring for it, clutch and brake pedals and lines, all the shifter linkage and lines, tranny, clutch/flywheel, new motor mounts (manual ones), and anything else that I'm forgetting......
    I think it's more work then you want to do but I could be wrong :?
    Tro1086 Guest
    Get it, Sell it, use the money to buy a manual Corolla, or a different car maybe.
    Theres lots of work involved in a swap like that.
