Engine When to change spark plugs?
Discussion in 'Powertrain' started by Phozenstone, Sep 1, 2004.
    Phozenstone New Member
    hey i bought my car brand new in 2001 and i have driven the car 48,000 miles now, i still have the stock denso iridiums in it but is it almost time to change them? also wut other things should i do to make the car run smoother?
    CraigW New Member
    If it is a Corolla the plugs are supposed to last 100K but should be changed between 60-75 k to keep them from seizing in the heads, Go only with OEM original plugs $13 each.
    There are no plug wires, distributer or rotor button to change on these models.
    The anti-freeze is supposed to last 30k Transmission service at 60k
    CW
    corolla_man_j Guest
    I can vouch for them being good through 100k. I didn't even thing about changing them until it started to miss, then I did. I got my plugs OEM for under 5 a peice
    CraigW New Member
    If you were to take them out and re-install them (maybe w/antiseize) they may easily last until 100k, I just was worried about not getting them out.
    $5 each is a good price for OEM Iridiums !!!
    CW
    toyotaspeed90 New Member
    Bellingham, WA
    i would change them when they're fouled out
