wheel re-invented
Discussion in 'General Discussion' started by ChristianVA, Jan 5, 2005.
    ChristianVA New Member
    thats gonna be a bitch to mount! ARGh!
    Luckily, you don't have to mount the tire to the wheel - it is a special one-piece wheel/tire combination - buy it as is. So you will be stuck with whatever style of wheels are cranked out for those.
    toyotaboy New Member
    lith, IL
    wheel re-invented
    michelin has created the better "no-air" tire that uses rubber spokes to cushion and support... They say not only would it eliminate blowouts, but it'll give up to 5x better lateral support for better handling
    http://www.nytimes.com/2005/01/03/a...ner=rssuserland
    Me likey!
    kickarse Guest
    AMAZING! To bad I thought of this already... ahahahahahah!
    Barnacules 100101101011011
    Duvall, WA
    I feel sorry for tireshops that have to get these on the RIM :)
    rolla02 Corollalcholic
    Delaware
    Yea thats the truth man, they already have a hard time putting tires on rims now. LOL
    wukong Banned
    there is a better tire comming out that uses air though. Its thicker,stronger, and lighter. You can drill a hole in this tire and not feel anything till 30mph.
    93corolladx Guest
    Sounds like a cool idea. It doesn't seem like a new idea though. I used to build battlebots and everyone would either have all rubber tires or fill pneumatic tires with foam so a puncture wouldnt keep the robot from moving.
    Speed_Racer Guest
    Not the same. They are saying this will still have the give like a tire filled with air. A current tire is really part of your suspension. That's why when you go with lower profile tires the ride gets stiffer, because there is not as much sidewall to allow flex.
    Do you know how rough a car would ride with solid tires. Let alone a sporty car with stiff suspension and solid tires
    SkyAce2004 New Member
    like a trailer with no suspension :p those things bounce if u go over a bump and there is little to on load on it, heh
    alby13 New Member
    "... and frivolous questions like the possibilities of chrome-plating."
    i liked that. i love the new technology!
    sting Guest
    man if i could only ave tires they used in STOMPER toys... ha, ha, ha...
    91DX Guest
    it says u could re-tread the tires. does this mean u can go from an all season tread to an all summer tread at will?
