Engine What to do w/ Flexible pipe
Discussion in 'Powertrain' started by 90rolla_4, Jul 25, 2004.
    90rolla_4 Guest
    I think I have a hole in my flexible pipe down from the exhaust manifold. I can't really tell where else the noise is coming from so I'm guessing their. What can I do about it? Do they make a replacement for it? I imagine if I take it to an exhaust shop its going to be costly....
    corolla_man_j Guest
    They sell this aluminium exhaust repair stuff at walmart, I would imagine that if needbe you could use that
    93rollaracer Guest
    could be a cracked exhaust manifold too...pull off the cover on it and see if there's any cracks. otherwise, just get a new downpipe from the dealer ship and slap it on there yourself...it involves removing and replacing around 6 bolts.
    but of course if you're running 13's then you're probably not using a factory exhaust ;)
    90rolla_4 Guest
    LOL nice one! Acutally I just replaced the "exhaust manifold" about 2 months ago, and I hope that wouldnt be it. It looks pretty clean to me. I climbed under the car when it was running and could hear the leak but could not determine the exact location. But was guessing the flexible pipe. If I bought that kit at Wal-mart wouldnt it end up braking b/c of the flexible pipe moving so much due to engine movement? Due they sell just the flexible pipe seperately? If there is a place that sells it, I would just try to weld it on or something.
    Lekz Guest
    either way u need to take it to an exhaust shop unles u do your own welding. Just take it to your nearest one and get it fixed...no biggy
    93rollaracer Guest
    did you replace the gasket between the exhaust manifold and downpipe when you replaced the manifold...that could be where it's coming from
    90rolla_4 Guest
    yeah i replaced the little ring, and then the gaskets. I will probably end up taking it to en exhaust shop just to see what it is
    93rollaracer Guest
    just remeber...if all else fails, duct tape fixes anything
    90rolla_4 Guest
    Are you being serious w/ duct tape? I still havent gone to the exhaust shop but I notice that after I run the car for a good couple minutes the noise seems to drop, but like when I first start the car its real loud.
    toyotaspeed90 New Member
    Bellingham, WA
    the manifold should be good..... he got it from me (i took it from the 4afe when i had it).... it seemed to be a different design than the ones that crack that i've seen.... it was more like a stock 4age cast iron manifold
    anyways, yes you can get just a flexpipe
    90rolla_4 Guest
    thanks thomas, but where can I just purchase the flexible pipe from? I dont have any mad cash flowing through, so I'm on a tight budget. The manifold is still in perfect condition, I rechecked it and everything works good.
    93rollaracer Guest
    and you're gonna have even less money after i beat your ass saturday :D
    but you could probably just call up a toyota dealership or stop by autozone and they could help you out.
    dw1986 New Member
    north royalton, oh
    i had a flex pipe problem too. the whole thing was shot so they had to put a new one in which set me back 225 bucks. really sucks :mad:
    90rolla_4 Guest
    Serious, 225 bucks thats not good. That will set me back somewhat.
    93rollaracer- dude shut up man, if I dont get this problem fixed I'm not racing!
    dw1986 New Member
    north royalton, oh
    yeah i know i couldnt believe it! come to think of it i think i shopped around and got down to about 170. 225 was the highest price.
    90rolla_4 Guest
    It would have to be welded on correct? Where did you end up buying that part at? Or did the exhaust shop supply it
