Engine what is this rotten egg smell from?
Discussion in 'Powertrain' started by James, Jun 23, 2004.
    poke holes thru it with a broom stick. :D
    do you have an automatic tranny?
    03silverrolla Guest
    03silverrolla Guest
    I have a 98 corolla with approx 114,000 miles. When I am going uphill I am revving in around the 3000 rpm range. I get this rotten egg smell. Does this mean I might need a need a new O2 sensor or a new catalytic converter? I also recently put some fuel injector cleaner in when I got my last gas fill up? Could this be what is causing the smell? Just curious.
    corollinout New Member
    i know usually its from the catalytic converter
    Mike4831 C-Town Pimp
    Statesboro, GA
    i just asked some honda techs and they said it could be a couple of things but it is prob a catalytic converter
    The reduction section in your catalytic converter, the part that changes NOx and some CO (carbon monoxide) back to N2 and CO2, also has the tendency to start absorbing SOx, or oxides of sulfur when its internal temperature drops below about 500°C. As Pat stated, sulfur is a natural contaminate in most fuels which, when burned, are emitted as oxides of sulphur.
    When the engine is required to put out more power and the catalytic converter heats up over 600°C, the catalytic converter starts releasing the SOx as H2S and SO3. The SO3 has no odor but the H2S (Hydrogen Sulfide) gas does, which is what you smell. That usually means the reduction section of your converter IS working, regenerating itself, and purging the accumulated sulphur. The older your O2 sensor and catalytic converter is and the slower they react, the more H2S you'll tend to get.
    Because sulfur reduces the catalytic converters efficiency in converting NOx, it's conentration in gasoline and motor oil is being reduced in the U.S. (eventually close to zero) by EPA and CARB pressures. Most standard U.S. emissions tests check for NOx emissions but don't (yet) check for SOx or H2S emissions.
    Sulphur can be a normal impurity in the fuel.
    rolla02 Corollalcholic
    Delaware
    Cat Conveter is going bad, I had the same smell with my first car when it was going bad
    corolla_racer Guest
    I think it's the catalytic converter and it can't be the fuel injector cleaner that u just put in.....they are made it clean your fuel injector and they don't smell like rotten egg...
    corollarider19 New Member
    i had that smell when my clutch was going bad but listen to the experts lol
    Statesboro, GA
    well when the clutch went on my dads truck it was mostly a burning rubber smell. not really a rotten egg smell to me.
    capntoo New Member
    I usually get that smell after I eat Taco Bell.....;)
    03silverrolla Guest
    its funny though that its only when I go uphill.... and it also only started since last week. The reason why I was thinking that it was from the fuel injector cleaner was because it only started last week when I used the fuel injector cleaner. I was thinking it was from the loose carbon deposits. I sure as hell hope its not the cat b/c those things are expensive as hell.
    03silverrolla Guest
    besides that my mom has a 91 camry with approx 152,000 miles and originally cat.
    TurboRolla21 Guest
    Quit sprayin that nitrous! :)
    03silverrolla Guest
    hehe.... i dont use nitrous... I was wondering is there is a way to clean out the cat
    corolla_racer Guest
    [James poke holes thru it with a broom stick.]
    hehehe thats not funny man...j/k man
    w1ngzer0 Guest
    well, its called toyota using cheap cats. Most of the 03 owners complained about it. One guy got it replaced and wala no more smell
    blancokracker Guest
    well for the 2000 up vehicles its on as a glitch or whatever and you could take it in to the dealer to get fixed for free (but thats the vvti engine)
    03silverrolla Guest
    I also noticed that Im getting low highway mileage.... 29-30mpg.... I wonder if this could be the result of a bad cat also.
    03silverrolla Guest
    so Im not exactly sure if I do need to get my cat replaced or not.... im not getting the cans on the road sound yet.
    take it to the ripoff dealer and ask then what they think
    LoRolla Guest
    Just to let you know cats can go whenever. I had a 2001 Rav4 and the cat went at 35,000km. It happens and I hate that smell that comes from it!
    w1ngzer0 Guest
    one the 03 owners replaced his cat and no more smell. Its just like nissan with the feathering problem they don't want to deal with it.
