Engine what engine can I put into this car (a honda)
Discussion in 'Powertrain' started by 98tealrolla, May 5, 2005.
    98tealrolla New Member
    I know this is a toyota forum and I am a big toyota person but I was wanting to know whats the most powerful engine you can directly bolt-in to a 91 honda civic dx? I would go to a honda site but im too lazy. Im not too knowledgeable about honda engines. Thanks.
    teevee247 Well-Known Member
    Montreal, QC
    That is not a direct bolt in... you currently have a D15 (92hp), you could swap in a D16 from the Civic Si of the same generation (108hp)... a JDM ZC (they are pretty cheap, and range from 115 to 130hp), a b16 (almost a direct swap, easiest way is to get the mount kit from hasport.com and it makes 160hp)... also, a b18 from an integra (140~142hp) would bolt in, but you would need an OBD1 conversion (or maybe OBD2 depending on the year of the motor) whic is usually a pain in the ...
    polo708 New Member
    9thgencorolla.com
    the easiet and most common are the b16 and b18 motors... both are great and take to mods very well.
    yeah i think ill take the b16 motor.... does it have a decent amount of torque? and could I hook it up to the stock 5 speed transmission w/out any troubles?... i might just go ahead and do that if not too $$$$.. Thanks.
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    both of my cousins have 93 civics(one a turbo'd JDM b16 hatch and the other is a JDM b16) theres a kid round me that had an integra gsr and rolled it 3 times over, he took the motor out cuz it was still fine and put it in a 93 civic and it runs mid 14s
    chr12is New Member
    Toronto Ontario
    My brother has a 91 that he swapped a B16 into himself, he says it was dead easy, did it in a day because it is such an easy swap, B16's are really common, at least in Canada they are, and he found they were really easy to come across. The 91 gen is a really light civic, with that engine and the 5 spd, and he also has ignition, intake, full exhaust, eibach springs...etc, there is so much support, his car is crazy fast, he autocrosses it, and is really fast
    Any D and B can be done without big changes. If you want tq, go look for a CRV B20 or just go get a B18 type R for hp. :)
    You can't put K series eninge in without big mod. K series rotate on the opposite way than D and B series.
    with the hasport engine mounts it would be direct bolt in.
    renfield90 New Member
    Tempe, AZ
    It's a Honda. Pick your engine. :p
    Laz Z Kay "n00B, be kind"
    Biloxi, MS
    A Honda ECA1 engine, saves you gas. lol
    DArkwolf383 New Member
    Anza, CA
    not sure if it fits but jswhitney has a new motor they call a gx20 I think it's based off the k20 they say it has 270hp and 185lbs of torque.
    jcwhitney even lol in there sport compact section
