Engine What Clutch to Go with?
Discussion in 'Powertrain' started by speedymach45, Apr 10, 2007.
    speedymach45 New Member
    I have an 05 Corolla, and i need a new clutch. Right now i have no mods, but i plan on the exhaust, intake, pully... the norm bolt ons and stuff
    what do i go with?
    i have been looking at a Centerforse Stage 2 Clutch,
    http://www.horsepowerfreaks.com/pri...ts/part/Stage_2
    anyone know anything about that? or should a go with a stage 1?
    fuzionrolla Guest
    need a new clutch or want my corolla is ten years old and it had the original clutch for 8 years
    fuzionrolla Guest
    and if you want a performance clutch go with a stage 2
    cgreen38 Common sense, p
    Baton Rouge, LA
    Nothing wrong with Centerforce clutches. I got a quote for a stage 3 w/ light flywheel for about $550 installed. I'm still debating jumping on that deal. Just need the money. :)
    BTW, a guy in my area just got rid of his 750whp Civic and had a Centerforce stage 5 in it, and he said it felt as light and easy to use as a stocker. Something nice to remember about them. :)
    Dose anyone on here have a Centerforce clutch already installed?
    but thank you for your help
    misfit31fiend Guest
    I have an 01 corolla, i installed a new stage 3 clutch from gripforce and i hate it, I think a stage 3 is to much power for a corolla, when i take of on 1st the damm car shakes like crazy, the cluth has 2 much grip, so i would recommend you go with a stocker! or stage 1, nothing to crazy unless ur gonna do alot of mods to your car.
    fuzionrolla Guest
    shakes like crazy must be something wrong then how low are your rpm's when you take off
    misfit31fiend Guest
    well i have to take off on high rpm like 3 for it not to shake and it becomes pretty onnying, and when im on hills it sucks even more!
    well, i know i shouldnt be getting anything more than a stage 2, a stage 3 with little mods is not something i need. ya if its shaking there is deff something wrong with it
    Yeah, there is no need for stage 3 unless you're pushing more power.
    gridjockey Well-Known Member
    glendora,ca
    go with a stage one racing clutch from exedy . this has an organic clutch disc and heavy duty pressure plate. this is made by daikin and is used frequently by toyota. also invest in a longer actuating rod for the slave unit.
    jtweezy New Member
    Irving, TX
    haha...stage 3??? You dont need a stage 3 in a stock or modded corolla unless your turboed, but even then, a stage 2 will be more then enough..
    shubert_ae102 New Member
    de mountains :D
    ^^^ yeah too much and youll experience crank walk . the 4g63 mitsu engines are notorious for it .
    as for the violent shaking at engagement , mine did it too , it was the motor mounts , and also theinput shaft bearing.
