What C pillar??
Discussion in 'Interior' started by White Rabbit, Mar 11, 2003.
    White Rabbit Guest
    What C pillar??
    Hey guys I just got a White 2003 Type S Corolla , I hate the stock speakers so im changing em. Ive read the DIY on the rear speakers but im still stuck, Im not sure what im suppose to do after i remove the 7 plastic screws, i tried removing the plastic that the screws held down but i wasnt sure if i was suppose to take that cause it seemed that i shouldnt of had to do that to get to the speakers. Im stupid on this cause I keep thinking im gonna break something. So if u guys could lemme know what a c pillar is and if u could also help me out a lil more on how to get the rear speakers out :oops:
    methaneb Guest
    The C pillar is the plastic right behind the rear window.
    Your A Pillar is the bar next to the windshield, B is between the two windows, and C is the one between the back window and the rear window.
    White Rabbit Guest
    okay
    Okay, I thought that too but im still not sure what im suppose to peel/ take off to get to the speakers :?:
    oxymoron Guest
    Carefully pull the C pillar trim off (both sides) than you can remove the rear deck trim. The C pillar trim is held on by 4 or 5 (can't remeber) plastic trim clips.
    White Rabbit Guest
    Im still lost
    Damm im a retard about all this and im scarred to break something, is it the black plastic on the bottom from behind the seat or the greyish one on the top at the sides
    oxymoron Guest
    OK, here's a picture.
    I've circled the locations where the clips holding the C-Pillar in place are. If you look carefully, you'll see that two of them stayed in place when I removed the trim,
    White Rabbit Guest
    thanks
    thanks for the help guys, I finnaly got it out and have sucsesfully changed my speakers
    Sirdaver Guest
    Nice pic there oxy....very helpful.
    SSJ_Rolla Guest
    i think we are gonna need that pic on tha DIY
    methaneb Guest
    If oxymoron consents, I will add it...
    oxymoron Guest
    Go right ahead. You might want to grab it and shrink it a bit.
