Water in my trunk
Discussion in 'Interior' started by HPS, Nov 3, 2004.
    HPS Guest
    Water in my trunk
    Why is there water in the spare tire area? The rest of the trunk seems to be dry. What area should i look for to seal?
    Thanks
    1onelove
    slvr2000fdvspec Guest
    what year is your car?
    is it only the spare tire area?
    does it happen when you wash your car?
    Laz Z Kay "n00B, be kind"
    Biloxi, MS
    There should be a rubber thingy, all you have to do is pull it out.
    HPS Guest
    Why? to drain the tunk?
    There are two different rubber plugs that you might want to remove, make sure they are whole intact, and not broken. I know this because I used those wholes to put my wires through.
    CraigW New Member
    There should be a rubber drain plug that you can take out to drain.
    Could be the seals around tail lights or back glass.
    Fold down the seats put someone in the trunk with a flashlight and take it to the car wash and spray rear area to check for leaks.
    CW
    Montana Guest
    My car collected water back there too.
    After an accident repair from last year the shop forgot to add seal where the qaurter panel attaches to the trunk ridge. I added some rubber seal-maker and it did the trick.
    Sometimes the tail-light seals leak.
    The plugs are there so you can remove them for draining. Do you have a sunroof?
    HPS Guest
    Thanks for the help!
    I drained the trunk..I think its the tails. I got those clear corner ones and they dont fit 100%. I had them for over a year but now i park in an open area and its been raining alot.
    Corolla DX-R AE100
    Vancouver, B.C.
    my car had a leaky trunk problem on the left side... i still dunno where the water is coming from cuz no sign of leak anywhere[IMG][IMG][IMG][IMG][IMG][IMG]...
    CaptainCorolla Thread Captain
    Orange County
    I had a bad problem with this with my last corolla. The best product for sealing tail light leaks is silicon. Also, seal the top seam more so than the bottom or sides. Gravity is working hardest against you there. Most shops do a poor job of sealing the trunk areas after accidents because it's so hard to see where the leak actually is. My girlfriend's trunk is a swamp as a result of 2 rear end collisions.
