wat will b broken on warrenty?
Discussion in 'Stop, Drop & Roll' started by rolla05S, Dec 13, 2004.
    rolla05S Guest
    i want a lower drop than the trd spring give but worried i will void warrenty if i get tien s springs what will it void the whole thing or what?
    corollarider19 New Member
    use the search engine its ur best friend... no it wont void ur warrant unless that part u installed has caused a malfunction then it voids ur warranty
    exolyte Guest
    theres some huge paper or somethin that says the part cant void ur warranty unless it has a direct cause on the malfunction--but be carefull...if there is a way to link ur upgrade to a malfunction, the dealer will find it. the only thing i can think of that might be voided is the garuntee on ur shocks. they will wear down faster.
    polo708 New Member
    9thgencorolla.com
    If you are having engine trouble, they wont void your warranty because you have lowering springs on.
    Magnuson Moss Act
    end of thread lock it please
    e_andree E
    MD
    Magnuson Moss Act
