want hood w/ working scoops
Discussion in 'Exterior' started by locster703, Dec 19, 2004.
    locster703 New Member
    i want to buy a hood with working scoops or any design that allows more air to reach the engine i lost my hood for forgetting to put my pins back in and the car runs much faster with out the hood where can i buy one?
    slvr2000fdvspec Guest
    first off..how the hell did you lose your hood..
    Shifty SIdeways Noob
    Memphis,TN
    Then buy a stock hood and cut holes in it.
    Cape Coral, FLorida
    ive seen that done to a 240sx b4 ,didnt turn out too bad either
    corollinout New Member
    reading comprehension works great<br />
    <br />
    <br />
    <br />
    <br />
    the reason the hood scoop on &quot; her &quot; hood cracked is because of the workman ship, if it were done correctly then just bondo wouldnt have cracked<br />
    <br />
    even though i DO plan on fiberglassing mine on so i dont end up with a problem, mine not only bolted on, i used apoxy to basically glue it to the hood, holds great
    wrong...i assume you're talking about the Invader hood? that lets a buttload of water in.<br />
    best idea. that or fiberglass a scoop on a stock hood with &quot;functioning&quot; holes. just DO NOT use bondo...someone bondoed a scoop on her hood, and the &quot;seal&quot; created by the bondo cracked horribly.
    Cape Coral, FLorida
    i think some1 said that the vis CF hood works, it doesnt get air in the engine but it lets the hot air out without letting the water in
    Cape Coral, FLorida
    ok if sum1 were 2 glass a scoop onto a stock hood where should the hole be so you dont destroy your engine
    the hole, if positioned UNDER the scoop, wouldn't necessarily destroy it. it's riskier to have just random holes in the hood.
    Cape Coral, FLorida
    what about cars with stock hood scops like evos and sti's how do they dispel water?
    ...water generally doesn't go up the scoop. since you brought up the VIS hood...the only one i know of made for corollas that has a scoop is the invader, which has a REVERSE scoop...which successfully directs water INTO the engine bay.
