Engine VVTI = VTEC???
Discussion in 'Powertrain' started by tegra2rolla, Jan 13, 2004.
    tegra2rolla Guest
    VVTI = VTEC???
    I have a question on VVTI vs. VTEC... I heard that VTEC engine will 'activate' the VTEC once the rev is up to 5.5Krpm and you will noticed a sound from the engine.
    Do VVTI engine do the same thing? If so what is the rpm that will activate the VVTI feature?
    Just curious that what our VVTI engine will do. Thanks.
    stinky Guest
    VVT-i is NOT = to Vtec. our engine will always adjust just the spark to make most power and best economy. Vtec is a whoole diferent cam profile. Engagement is different for every version, some engage at or around 4k rpm as well.
    bewildered_spruce Guest
    VTEC works the same as the lift in VVTL-i. the camshaft (i know its on the intake cam but i dont know about the exhaust) on those engines have extra, more aggressive lobes that the engine switches to at a certain rpm to make more power
    RexPelagi VDub
    Canton, Ohio.
    Ya Im going with spruce on this one. I also heard that VVTL-i is closer to VTEC.
    stinky Guest
    This is the scale for vtec vs vvt-i
    lowest = vvt-i
    medium = Vtec
    highest = i-Vtec & VVT-li
    js10coastr Guest
    VVTi stands for variable valve timing with intelligence. Essentially what it does is to change the open and close time of the valves to allow for optimum performance. During high engine speeds the cam position is altered so that the intake valve closes after Bottom dead center (BDC). This allows for more air to enter the combustion chamber, since the air carries enough momentum during the intake cycle.
    You really can't compare Vtec to vvti, it's apples and oranges...Vtec also has different types which makes it even harder to distinguish against.
    In simplistic terms, VVTi is continuous through out the rev range and can be altered on the fly. Vtec works on a seperate cam profile, this means that it "kicks in" at a certain range. The timing and/or lift can be different. VVTi, has an infinite number of adjustments, Vtec has 2 options.
    alpha-vvti Member
    so if someone were to race a Civic EX (stock) with a corolla (stock)
    civic has more chance to win?
    i would say the corolla would win cuz with VVTi it doesn't have to wait for anything to kick in, the civic however doesn't make most of its power until the VTEC kicks in at, lets say just for an example, 4k rpm... it sort of like the celica gt-s. u dont have hardly any power until u hit lift (or in this case vtec)...
    but don't take my word for it cuz i dunno bought i-VTEC and later models might have better low end power
    crovax New Member
    well, stupid honda says the old D17 motor found in the civic EX has vtec...in reality it doesnt. what it has is some lesser form of vtec maybe only on the intake side or something, but i know the D series motors, and even the K series motor in the civic SI and the RSX base model dont have realy true VTEC
    alpha-vvti Member
    isnt the RSX equipped with the i-vtec though?
    Blk03Corolla Guest
    the type s yes it is does producing 200 hp but not the base rsx with 160 hp
    WebMasta33 Guest
    ...deleted I got a virus warning on the page.
    RexPelagi VDub
    Canton, Ohio.
    If the civic didn't win it would be their fault in my opinion. There is no reason why it shouldn't. A good driver would know that VTEC only works at 4+, for example, and would thus rev in neutral at 4000 until he shifted into 1st.
    Tro1086 Guest
    reving in neutral dose no good because your not getting any of the power to the ground so its pointless to just sit there and rev. You just have to go and wait for your RPM to climb into the 4+ range. Even feathering the clutch and holding your RPMs above 4 dose no good beacause becaus if your clutch isnt all the way out then your not getting 100% of the power to the tranny which means your not getting all the power to the ground.
    i agree 100%... say u both have bout the same power, the corolla's gonna take off quicker cuz it doesn't have to wait for anything to kick in while the civic's gonna be playin catch up cuz it doesn't make power till higher rpm's
    AznRolla Guest
    the base RSX does have i-VTEC... my sister has one. the s-type is runnin diff. compression and requires higher octane fuel... thats why it has 200 hp
    RexPelagi VDub
    Canton, Ohio.
    So you guys are telling me that if your at 4000 or 5000 in neutral, shift into 1st while at 4000 like a drag start, your rpms will drop to 1000 or so and u have to build them all the way up again? I didn't think that would happen. It doesn't happen when I shift from N to D in my automatic corolla, and I do it at like 2500 rmp-Ya i know a few more times and my tranny going to drop out.
    well u can always do that but if u have an auto and want to drive it more than once than u basically have to start from idle... on the other hand if both cars were manual then it would be a tight race, slow but tight :wink:
    RexPelagi VDub
    Canton, Ohio.
    Hey I've done it like 3 times and I'm still going strong lol
    1ZZ-ROLLA-S Guest
    Blk03Corolla Guest
    I didnt realize they had the same engine I thought the Rsx base was just a v-tech engine pretty much like the base celica to the gts celica. And a stock rolla 5 speed will beat a stock civic ex 5 speed that is same driver in both cars.
    TheDruid Guest
    the civic Vs. Rolla topic maybe about manual trannies...(wish my rolla had one..=*/...)
    but lemme just say say that a stock Auto 03 Corolla S(running on almost bald stock tires with 25K Miles, Full tank, and guitar amp in the trunk) will chew up an Auto 03 Civic Coupe EX with CAI, straight pipe exhaust, empty cargo, and carbon fiber hood. At launch it may even out...but thanks to Toyota...the 3rd gear's ratio is great!! that's when you start pulling away...and i mean...PULLING AWAY>>>>
    RexPelagi VDub
    Canton, Ohio.
    Dont get your hopes up. I cant beat my friend's automatic 1993 Accord (stock 130 hp). This may be because he has headers, CAI, and an exhaust, but still its very uncool.
    [TRD]Rolla Guest
    people actually do neutral drops in here? :roll:
    RexPelagi VDub
    Canton, Ohio.
    Ya why do you ask?
    lostboy New Member
    I think the Type S rsx is more like the GT-s Celica ... with a high lift cam that switches at a certain rpm ... the Type S has different intake runners that also switch to compensate for the cam change.
    The base rsx says it has an I-VTEC ... but it's an economy version that saves gas and drops a valve or so under 2k rpm ... I have a base rsx ... notice how it drops to 700rpm when you let off the gas? even when you go 40mph ... it helps to save gas ...
    I was so wierded out when driving the corolla and the rsx ... i didn't feel much of a difference in power ... at first ... now i realize .. the corolla has more low end power and the rsx has a much higher high end power ...
    rsx has no torque either ...
    How much does the civic weight vs the corolla?
    CorollaAltis New Member
    civics have 125hp and the accord has 130. 5hp makes a difference. but there's a realyl good way to launch with autos without doin a rev drop. it can literally make u "jump" ahead of the other cars at start and The Druid did it. but then so did the guy that he raced cuz that's his co-worker's civic.
    Corolla_Racer956 Guest
    well i have raced a stock civic with my stock corolla and let me just say that i am prous that corolla's come with a vvt-i engine than a v-tec cuz its true, the civic had to play cath-up with me during the whole race and i took him by like half a car.
    And just a litlle funny comment me and my friends say that VVT-I stands for
    VERY
    V-TEC
    TO
    INTEGRAS!!! i dunno i thought it was funny!!!
    MrDisco99 Guest
    Think about what's happening in your transmission when you do that. The engine is up there revving, but your wheels are having to catch up to it. During that time, something is slipping somewhere. Most likely your torque converter is churning up that tranny fluid and burning it up. You're also possibly scraping up the permanent clutches inside your transmission.
    Keep doing that and one of these days you'll put it in gear and not go anywhere.
    RexPelagi VDub
    Canton, Ohio.
    Ya but as long as its within 2 yrs, its cool cause im under warrenty.
