Engine VVT-I
Discussion in 'Powertrain' started by bxman89, Aug 12, 2012.
    bxman89 Well-Known Member
    WILL THIS MOTOR BE A DIRCT FIT FOR MY98 COROLLA VE??? NEED HELP MOTOR IS DEADING SLOWLY.
    roachrolla likes this.
    no. Different air sensors, engine ecu, tuning, etc.
    It may work in the car but none of the vvt-i features will work.
    tuning i can get done and when i buy motor ill get everything that comes with it. btw are the motor mount different???
    If you get everything including the harness, then everything should plug and play. You probably need to repin the body connectors to match your car, and match up accessories/features in your car vs. the engine. This is for 00-02 Corolla vvti engines. Celica ECUs are in the engine bay so a Celica harness wouldnt work well for your application.
    Engine mounts are the same for all 98-02 corollas. No matter where the 1zz comes from, just use your own mounts with the swap.
    Just checking in for any update.
    x11
    /update
    FUCKIT
    x12
    x13
    Milky Enlarged Member
