Engine vvt-i swap
Discussion in 'Powertrain' started by rainbow_star, Aug 31, 2005.
    I don't know. But I think it's not worth that much $$$ just for the extra 5hp.
    bomextoyrolla Guest
    vvt-i swap
    i have a 98 corolla non vvt-i and im wondering if a vvt-i head from a 01-02 (i think) can fit onto the block of mine right now?
    prrolla New Member
    yes it would but you'll have to change your harness and ecu, 00-02 all had vvt-i. i'm doing that same swap but mine will be a complete motor buildup from a celica gt
    prrolla New Member
    well in my case im going with a bigger bore, bigger injectors, 3angle valve job, a bit of porting on the heads and few other things my goal is to reach or be as close as possible to 200hp without a turbo or S/C.
    slvr2000fdvspec Guest
    good fucking luck, i haven't even seen people that are boosting hit 200 yet..
    sxlostv1 New Member
    Los Angeles
    just swap in a built 20v. save urself some money
    rolla96dx New Member
    silver2000, ur signature matches... but ur right...
    doing just the head swap isn't worth it. but to be honest, to try and crank any real power from one of toyota's F heads isn't really worth it..
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    Yeap exactly what I'm doing on my 98' and then turbo.... the works will probably put u at close to 120 hp or so but not big gains with all the boring out and crap, only way u'll make it happen is if turbo comes in. Vortex is pushing over 200 easy right now on the stock 1zz he has on there.
    prrolla New Member
    i'm sure with the right parts and tuning it's possible. have you guys seen the http://www.jotechracing.com/html/pr...ectVehicleID=55 of course it's turbocharged boosting about 26psi at 500+ whp but it has a FE head. my future plans for the motor would be adding the S/C but at first i wanna break it in without the forced induction and dyno it to see where it's at.
    COROLLA1ZZ New Member
    Right now my engine in my 01 has been done with a big bore kit with wesco 8.8:1 pistons,crowler rods.Arp head studs and valve job with mwr valve springs.My head has been p&p.Ahigh valume oil pump.I am ready for turbo but right now I have to deal with only 98hp.
    prrolla New Member
    well with the lower compression you probably lost a bit of hp but not much probably what type of engine management do you have?
    was going to run power fc but couldnt get it to work.I am running a modifyed ecu but I will be running an emange. my slushbucket tranny is what hurts me.
    prrolla New Member
    oh ok, you i had heard and read that by going with a bigger bore can increase the power by 20% i guess depends on size and all. what size did you bore it out to? i'm thinking of going with 82mm
    I am at +0.5mm (+ 0.020") which is 82mm
