Using the high low converter on the stock radio?
Discussion in 'Interior' started by Blue_Diamond, Jul 19, 2003.
    Blue_Diamond Guest
    whats up corolla crew,
    I want to put a system in my car but i dont want to change the stock radio. So i was planning to use a high low converter with an amp. I am going to hook up two 6x9 and one 12inch sub. I want to know how will the high low converter sound on the stock radio. Will it sound clear or will it sound dissorted. thanx
    if any one has a pic of their high low converter it would be helpful.
    razz422 Guest
    This is mine, and it sound clear to me.
    I know it's messy... :(
    I'm too lazy to make them neat.
    Someday when I have time.
    ConwayJim Guest
    Couldn't you just use the X overs found on your amps? My old head unit didn't have a sub out/level but still had one pre-out. I connected that signal to my sub amp, and just used the x-over on the amp to feed low pass signals to the sub.
    and used the other amp's x-over for the highs for the front
