upgraded brakes
Discussion in 'Stop, Drop & Roll' started by JunGLe ChiKen, May 22, 2005.
    JunGLe ChiKen New Member
    upgraded brakes
    i wanna upgrade my stock brake pads and rotors(oem size) to some performance brakes...any recommendations on wut kinda pads and some slotted rotors that are OEM size too. and i wanna upgrade to some steel brake lines also
    mingww New Member
    Vancouver, B.C
    I went back to Taiwan last month, and many people with 98~02 did a 97 caliper conversion.
    97 Caliper/torque plate are complete bolt on to 98~02.
    pads are bigger, and the caliper piston is bigger too.
    and plus a Brembo Blank rotor will be real nice.:)
    hope that helps
    You usre they use 97 rolla brake, not 97 carmy?
    starion88esir Guest
    So 97 brakes are an upgrade to 98-02 brakes? Would any 93-97 caliper/torque plate work?
    powerslot makes good slotted rotors, as does rotora. stay away from slotted brembos and slotted apex and shit like that
    Interesting. The MR-S shares the 93-02 Corolla's 4x100 bolt pattern. Any chance it's brakes could be swapped into our cars? In any case, Dr. Tweak has a rear disc conversion kit out now and I believe he's working on a front big brake kit.
    starion88esir Guest
    Link? Pics? Price?
    Check some of the threads out at <a href="http://www.VVT-i.net" target="_blank">www.VVT-i.net</a> or his website, <a href="http://www.phoenixtuning.com" target="_blank">http://www.phoenixtuning.com</a>, for more details.
    JDLangevin Guest
    mingww New Member
    Vancouver, B.C
    i don't know about camry, but iknow certain year of camry will do.<br />
    <br />
    basicly, Toyota Exsior and 97 Toyota Corolla will be able to convert to 98~02.<br />
    <br />
    however, Exsior's caliper will need thicker rotor(25mm), and 97 corolla will use 22mm rotor.<br />
    <br />
    if you are able to read on Corolla Fleet's website, do a search, then you will find it out. i discuss this with HOTHBL in Taiwan, when i were back there.<br />
    <br />
    i didn't bought new caliper to convert because i might not keep my car for too long, so i decide not to.
    mingww New Member
    Vancouver, B.C
    you can see that as upgrade, many ppl in Taiwan go with this route.
    so far, i heard good review with them.
    mingww New Member
    Vancouver, B.C
    nono, it's only signle piston, but with bigger diameter.maybe 3~4 mm i believe.
    and the pads are bigger too
    ming, are you talking about the dual piston 10.8&quot; front disc brakes as found in the AE101 FX?
    1 PHAT TOY Guest
    93-02 Corolla 11 inch 4 piston upgrade
    Applications
    1993-2004 Corolla (all) Specifications
    11 inch 4 piston aluminum caliper front upgrade
    Available Photos: 1,2
    Description
    Here is a new kit for the 1998-2004 Corolla using an OEM style rotor with the lightweight 4 piston aluminum calipers. Kit comes with all the parts needed to swap on the 11 inch upgrade, including the slotted & drilled rotors, 4 piston aluminum calipers, aluminum mounting brackets, braided steel front lines, performance brake pads, and all attaching hardware.
    Calipers now available in RED.
    Kit will fit 15 inch wheels.
    ITEM: Corolla11
    Regular Price $950.00
    Your Price $800.00
    Available Options and Accessories
    polished calipers +$125.00
    red calipers +$150.00
    Please Call to Order - (602) 323-2110
    Items Recommended With Purchase
    Team Dynamics Pro Race 1, 15 x 7 wheels
    93-02 Corolla 12.2 inch 4 piston upgrade
    Applications
    Corolla 12.2 inch 2 piece rotor 4 piston caliper front upgrade
    Description
    Here is the 12.2 inch 4 piston caliper upgrade for the 1998-2004 Corolla. Using the same basic system as the 11 inch kit, but with a larger 12.2 inch 2 piece rotor, this kit will deliver all the braking you will ever need. Comes complete with all the parts needed for the front including: lightweight aluminum 4 piston calipers, 12.2 inch slotted & drilled 2 piece rotors, aluminum center section, braided steel front brake lines, pads, aluminum mounting brackets, all attaching hardware.
    This kit will require a 16" or larger wheel.
    ITEM: Corolla12
    Regular Price $1,250.00
    Your Price $1,050.00
    in that case concerns would be where to find replacement pads and discs when time comes. But i'm not sure if there is a toyota here which runs dual piston calipers with a 4X100 lug pattern either.
    e_andree E
    MD
    Id personally stick with OEM pads with a slotted rotor.
    mingww New Member
    Vancouver, B.C
    yeah, you will need to get 97 pads if you did the upgrade,
    i have no idea about MR-S, if they acutally fit, that will be an even better upgrade!:)
    The MR-S has 2 piston calipers? I have no idea myself. But I do know the rear discs and calipers from the MR2 is interchangable if you do a AE100/111 rear disc conversion.
    noo i dun wanna do ne conversions n shit, i jus want OEM sized slotted rotors and good sport brake pads! ne suggestions?
    Powerslot rotors and Hawk HPS pads
    mingww New Member
    Vancouver, B.C
