Engine Upcoming: Phoenix Tuning Stage I Turbo Kit ('93-'97 Corollas)
Discussion in 'Powertrain' started by JDLangevin, Apr 24, 2005.
    JDLangevin Guest
    This isn't a for sale thread, just an announcement of what's coming.
    The Phoenix Tuning Stage I Turbo Kit will include the following:
    Garrett T3 Turbo Super 60 compressor, .48 turbine
    12:1 FMU (Vortech most likely)
    TurboXS Boost Controller
    Phoenix Tuning Turbo Manifold (you must send me your old manifold as a core)
    Spearco intercooler
    TurboXS BOV
    Intercooler piping (that will actually fit)
    Water and oil lines
    Downpipe
    Walbro 255lph fuel pump
    Oil pan with turbo oil return connection (you must send me your old oil pan as a core)
    Boost guage
    Several upgrade items will be available, such as guages and whatnot.
    The price of the kit will be $2700 shipped. The kit will be good for 7-8 psi and will be a bolt-on kit, meaning you should be able to install it in a day with hand tools. I will provide full instructions. This is a tried and true setup that two friends of mine have been running for many many miles with good success. It makes around 160/170 hp. Premium fuel will be required.
    I'm picking up a Corolla to build the prototype on, and then I'll start producing these. It will be a little bit but I'm hoping to have the first kits ready to go for early fall.
    If anyone wants to make a deposit for dibs on the first kits, that will help me get them developed faster and out the door.
    I've got details coming in another post for the Stage II kit which will include the '98-'02 Corollas, just hang onto your panties already.
    200 hp would give a 2400 lb. corolla a lb/hp ratio in the neighborhood of Boxster.
    *Edit* 160/170 brings the lb/hp to around 14.5.
    JDLangevin Guest
    Update:
    I've been able to work out some deals on the pricing and I'm passing these savings on. The Stage I kits should now cost only $2400!!!
    red 03 corolla s Guest
    can you make a kit for the 03+ corolla's........please:)
    yeye Guest
    Once he is done with this kit, he will be doing one for the 03-04 owners too!
