Uneven treadwear
Discussion in 'Stop, Drop & Roll' started by ctsire13, Jul 12, 2004.
    ctsire13 Guest
    Uneven treadwear
    I have a lot of wear on my front tires, on the insides, outsides look fine...driver's side is much worse than passenger's. the rear has no uneven wear. I have 205/40 R17 and tein S tech springs. Any body else have this kind of wear or have any suggestions.
    polo708 New Member
    9thgencorolla.com
    After you had the springs installed, did u get an alignment? It sounds like your running a negative camber, a standard alignment will fix it. :wink:
    w1ngzer0 Guest
    what he said 8)
    APC_MATRIX_ Guest
    And stop burning out cause the drivers side will wear faster if you keep that up.
    White Rabbit Guest
    Yeah get an alignment, It could also be an bit of toe out, Shops usually dont charge u to check ur alignment, atleast the ones here dont.
    ctsire13 Guest
    thanks for the help...I suspected the alignment....It is definately not burnouts, hehe....I will get the alignment looked at but will probably wait until I get new tires since these are so bad and I will be getting wider tires. What do you guys think?
    polo708 New Member
    9thgencorolla.com
    Get the alignment ASAP... it will help your gas mileage and its safer with the added traction. You wont need an alignment after you change tires, so get it now if you can. :wink:
