Turn signal not working
Discussion in 'Interior' started by slow_rolla, Apr 27, 2014.
    slow_rolla New Member
    2000 Toyota Corolla CE
    Okay, so a buddy of mine recently bought a 2000 Corolla, base model. He has been having this odd problem with his turn signals. His right turn signal worked just fine. His left turn signal wouldn't work unless he held it halfway. So we figured it was a problem with the actual indicator shaft thing. Went to the junkyard earlier and got another one in better condition than his, plugged it in and the left turn signal started working! Then once we got done celebrating we realized that the right stopped working... -.-
    Idk if me and him are missing something or what. Anyone have any suggestions on how to fix this? Maybe a loose ground? Anyone have a wiring diagram? Thanks for any help
    You might just have to clean the contacts on the switch and make sure it's working
    Has he done a cluster swap from a different year? Some years have issues with the turn signals. Ask him if his rear defroster works. If it's the original cluster, clean all the contacts on the connections, and I'll see if there's a fuse or relay or something.
    ^^^^ this
    His fuel gauge wasn't working in his original cluster and some random guy gave him a cluster, the same type of cluster for free. Unfortunately he was having the same problem with the other cluster. I will ask him tomorrow thanks Mack
    hmm well I think it's more than a coincidence that I was correct on a new cluster lol. If it's been swapped once it could have been swapped twice but that's a little less likely.
    Haha bro tbh I have no idea what hasn't been done on that car, there is at least a gallon of body filler spread across all the panels. Evidently it was a company car or something and the previous owners really did not care. I am just trying to help a fellow 8th gen driver out you know? But this turn signal thing is just odd.
    We'll check all fuses and relays first, and if not that, then find another cluster from the same year.
