Forced Induction turboing a 00 celica 1zz
Discussion in 'Powertrain' started by m4tt, Jun 14, 2010.
    m4tt 2000 celica
    south tx
    i have a celica gt with a 1zz.....i want to boost it, im working on internals right now any advice is good
    ExDream Member
    SoCal
    this is random but , im trying to know if a celica 1zz turbo kit would work on corolla 1zz lol
    Nice thread jack. No.
    I suggest contacting Doctor Tweak from Phoenixtuning.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    rods and pistons are sure away NEED TO CHANGE on 1zzs.... too weak for massive boosting...
    for mild 8psi or less boost they´re ok... at best
    the rest is... get a nice mid or small sized turbo and IC if you want and some additional injector or go 440c or or or o r or or or or....
    m4tt 2000 celica
    south tx
    well im waiting for prices i have 1200 to put into internals im getting pistons rods a new crank [mine was turned] and a stage 1 cam....im looking at a jdm turbo its a small universal one and a mishimotto race intercooler. oh ya the pistons will put at an 8 or 8.5 to 1 compression
    my bad
    probly wouldnt be hard just different routing. im not using a kit
    The thread jack wasn't you. It was directed at ExDream. lol What are you doing about the turbo manifold?
    m4tt 2000 celica
    south tx
    oh i havnt even looked for a manifold. just gettin the engine ready for it right now but this shop is kind of slow, idk if theyre just busy or what
    The manifold is one of the most important pieces. I would suggest you source all the parts before you commit to beefing up the motor. Check out MonkeyWrenchRacing. They have turbo manifolds for the 1ZZ.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    yeh... N/A 1zz 8.5 sucks balls...
    itś like downgrading to a 1.5 yaris engine
    that is...
    until you turbo it...
    m4tt 2000 celica
    south tx
    lol hopefully i wont be a terd for long
    m4tt 2000 celica
    south tx
    im having some trouble finding parts for my car.
    i need
    8.5:1 pistons probably wiseco
    stage 1 cam probably hks
    rods 91.5mm stroke probably crower
    and a new crank a stock one
    Any help is good, im in south houston area
    SaberJ2X Lurk MOAR
    Mayawest, PR
    m4tt 2000 celica
    south tx
    thank you very much
    las vegas
    why lowering the compression 8/8.5 and not stock compression?
    He's boosting.
    m4tt 2000 celica
    south tx
    is it even worth lowering my compression, the pistons are the most expensive part of my build right now. i dont plan on boosting over 10 psi and i will be driving this car a lot around town. this is a 1000$ question
    I don't see a need for lower compression pistons. You're not even going to boost at 1 bar.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    ^ what he said...
    m4tt 2000 celica
    south tx
    alright thank you thats a lot cheaper now
    Did you say your budget was $1200? That will only get you new pistons and any stage Cam, because they are all on sale right now at MWR. You can't do much else with that amount, but I like the fact that you will/plan to spend it on building your 1zz-fe. Try this kit. I haven't purchased from them, but it seems like a damn good deal to me.
    http://www.importperformanceparts.net/imports/pek-toyota.html, No. 25, Part No. EKTO39LMPX, at Tel No: (603) 378-0090
    m4tt 2000 celica
    south tx
    that looks pretty good right now, but i have a few people thinking about throwing some money into my car, plus my dad wants to help. i might get the complete engine from mwr with cams and stuff all done, its 5000 but every week i get more in the bank its just a matter of time
    m4tt 2000 celica
    south tx
    i ordered a 1zz with 20k miles on it, any tips for doing the swap
    I thought you were just boosting the current you have in the car already, so why did you order a second engine?
    m4tt 2000 celica
    south tx
    i found this 20k motor for 1400$ and thats almost 150k miles less than my current motor. i figured itd be better to turbo a lower mileage engine
    Oh that's a lot of miles lol I didn't know you had that many on the original mortor. The 1ZZ you ordered, was it with VVT-i? I don't know if they added that on later for the Celicas as they did the Corollas. Hopefully you didn't buy an engine with older technology.
    m4tt 2000 celica
    south tx
    yes lol it has vvti. the only thing is the engine drained my checking account so now i have to wait. doing the swap myself should keep me busy, and i can think things through
    Since it's the same engine, I can't imagine it would be too difficult, unlike going from one engine to a completely different one. Ok well since I don't know a thing about swapping engines, I will go back to just reading and give no more input lol.
    m4tt 2000 celica
    south tx
    Lol its all good ive done some swaps in camaros but my buddy knew what he was doing. Now hes a medic in the army
    whoa engine is already here, was fast
    m4tt 2000 celica
    south tx
    im so close to being done, the only problem so far is i broke the knock sensor. im also not sure if leaving the tranny in was a good idea, i should being putting the motor into the car tomorrow. ive changed the wiring harness out and installing the water pump, alternator, air conditioning, and the throttle once its on the mounts
    hrmmm....
    ... don't mind me i'm lurking this thread.
    for the record, you *can* squeeze out 10psi at sea level w/o any danger on a stock 1zz so long as you have good timing pull and fuel supply isn't a problem.
    MWR has decent parts for working up a Celica build, however (to answer the corolla question) you're better off building a custom log manifold on the Corolla platform. Once you start trying to pull funky equal length configurations you run out of room for decent clearance and routing of IC piping. However, in all cases, *anything* can be done. It's just how much effort, time and.... money you're willing to put into it.
    I suggest anyone wanting to boost a 1zz start by looking at a budget of 3500 and up. Anything less and purchasing "discount" parts is sure to get a "discount" configuration and end up melting down something.
    Just my 0.02 worth.
